Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Ross-tech Bleeding Issue 9N3
    May 2014
    Hey guys,
    SO I have an issue with my 9n3, the pedal is soft after working on the brakes and I have gone to the great expense of acquiring a Ross-Tech cable and doing a bleed through my laptop.
    The problem is when I go into the procedure, I get an error message in Block 002.
    This is a major annoyance as this was the primary function I was after.
    Any advice is greatly appreciated.
    Thanks in advance.
    May 2011
    Albury, NSW
    I know you're asking for advice directly related to the VCDS bleeding - but have you rotated the caliper 180 degrees when bleeding? That was the mistake I made and why I could never bleed my 9N3 brakes by myself. Apologies if it was obvious to you, but I completely overlooked it and had to drive to the shop with no brakes (luckily only 3 blocks and I stayed in first and used the handbrake haha!)
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    What's the error say? Using this procedure? Ross-Tech: VAG-COM: ABS Brake Pump Bleeding Did you allow air into the system, what jobs have you done on the brakes?
    New calipers or what?
    EDIT tried my Polo, same deal get an error too.
    Look in output tests, you can run the pump and also cycle all the valves to check them at the wheel. Follow the on screen prompts, press pedal etc wheel free, wheel locked.
    Maybe that will help?
    May 2014
    So I just replaced the discs and pads all round. I have tried the output tests but to no avail. I can hear the pump applying pressure to the corresponding caliper but nothing comes from the nipple.
    To my understanding the output test would only use a minimal amount of fluid and not constantly bleed out.
    Also I'm not sure what you mean by rotating the caliper?
    Quote Originally Posted by Blue Shell View Post
    Will fluid come out under gravity if you leave a minute or with a bit of pedal pressure? or is the bleed nipple blocked due to not having had a cap on it? In which case it needs cleaning out.
    Did you reset the rear calipers so the cut outs in the pistons are horizontal?
    gavin
    Aug 2007
    Plenty written on here about bleeding Polos, by myself and others, there is a totally different method to bleed them. Not like the conventional furthest to master back. If you opened it up you must follow it or you will be chasing your tail.
    Jmac
    Alba European
    gavin
    Wait, what?
    Cheap, Fast, Reliable. Choose two.
    Adelaide hills, SA
    To change the brake fluid or bleed the air from the VAG brake system, you need equipment similar to this one.
    Ross-tech Bleeding Issue 9N3-detailtemp500d42d8073f5-n1c4cgej-250000-jpg
    The cheap pressurised garden sprayer style ones, that people buy for cheap, just introduce moisture in the brake system and microscopic bubbles, don't use them. You wouldn't maintain the same level of safety that your Polo (any car) was built with.
    May 2014
    So I went through the output test and it felt better. But not factory better.
    I must elaborate, my front right brake is squealing and everytime I press the pedal I hear a wretching sound sort of hard to explain but it sounds as if it's realeasing suction or something.
    The pedal was not applying brakes as soon as it touched but now it is.
    I would really like to avoid getting a shop to bleed it as I've already gone to the expense of the dumb Ross tech cable that doesn't even work.
    But as a last resort how much would I be looking at?
    Jan 2009
    blankedy
    The computer bleed is for the ABS module from what I understand, its not going to fix air in the lines / not being bled properly.
