Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
Thread: Revo Stage II anyone?
  1. #31
    There was about 20hp or so difference between a tweaked Phase 2 and one without the tweaking. So there's room to improve power with timing for sure.
    When you are playing games like this, I think it's important that you can monitor how the engine's running afterwards. If you don't have easy access to a VAG-COM cable, you should think about getting one.
    Even something as minor as a spark plug can cause problems on a tuned set up that would go un-noticed on a std car.
  2. #32
    Nov 2008
    Not wanting to put a downer on what you are doing, but is there any point in taking a Polo to Stage 3 ? Wouldn't the money have been better spent on something else ie Audi S3 ? Just my opinion.
  3. #33
    Aug 2007
    GAV IS 100% Right , this wont even log a fault but the ecu might be pullin the timing back due to a duff plug or bad fuel, logging is the way, can in some cases be blowing the spark out, fit new plugs and its the missile it should be.
    Jmac
    Alba European
  4. #34
    Jun 2008
    I will try to get the stage 2 loaded either this week or next week depends on it needs a 4 bar fuel regulator or not!!
  5. #35
    Jul 2007
    Auckland, NZ
    HKOGTI - pmed you about Stage 2.
    I have VAGCOM, what should I be monitoring to make sure things are running smoothly? I have it, but I only use it to check for fault codes.
    I am sure I can make more use out of this $500 dollar item!!!!
    which channels etc?
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
  6. #36
    Jun 2008
    Confirmed by Revo, i will need a fuel pressure regulator for the stage 2 software....
    Stage 2 software delayed.... Need to get the FPR 1st...
  7. #37
    Jul 2007
    Auckland, NZ
    As advised Herman....
    Better to be safe. It's cheap from ECS tuning, just get it imported.
  8. #38
    Jun 2008
    Wahahaha...
    Cant wait, i am trying to get a FPR now...
    There is sard one for about 160 and apr for 200, ecs is 80...
    Tell me how it goes once you got the stage 2!
  9. #39
    Jul 2007
    Auckland, NZ
    REVO Stage 2 is finally in. The impression from driving around 80km, is that it boosts hard with peak of around 23-24psi. (recorded on VAGCOM as 24), and difference is that the boost will settle a little, but will keep around 20psi through higher REV range. It definitely has a lot more torque from my butt dyno.
    I am waiting for TIP pipe within a month, and that could make a difference in higher RPM I believe. The setting is quite good at Boost 7, Timing 7, and Fuel at 8. I could advance the timing a little higher as my VAGCOM readings were approved both by REVO at UK and in NZ. They said it's very stable now. I will try Timing 8 next month.
    Only down side I've noted so far is that the fuel consumption is now worse than Stage 1. I use to average 8.5 litres / 100km including city commuting in traffic, now on average I seem to be doing closer to 9.5-10 litres / 100km. I think I need to drive around more for the ECU to adapt to all the settings.
    It costed me about $150NZ for tune. Needed to pay another $150 for on road tuning, but feels worth it. Although a bit annoying as I can do this myself with my VAGCOM, but I cannot adjust settings.
  10. #40
    Jan 2009
    blankedy
    Thanks for the update mate.
    Can you tell us more about your settings (7, 7 and what do these mean? I don't know much on the Revo front, but their websites don't help much either...
