Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: reverse to 1st
    mdonohoe Guest
    Gonna be serious here.
    Either you got a r**ted gearbox with a wild bore inside or you need to learn how to drive a manual better.
    I've driven manuals that are anywhere upto 22years old, the only one thats EVER done this was a 1983 Diahatsu Charade with a 5spd manual & stuffed gearbox and even then it only did it sometimes.
    Matt
    Feb 2007
    Quote Originally Posted by mdonohoe View Post
    Not out of the question, mind you. I've had a chat to another owner who's ended up with a 'box full of neutrals in his Polo.
    If your car's throwing itself out of gear - you've got the same problem he did - get it looked at by VW...fast. His Polo went to VW on the back of a truck.
    I MUST double clutch my s2000 from 1st to 2nd if I'm nailling it or the I'll crunch the box, no question. Driving at slower speed it's fine but if I push it into VTEC, I've gotta do it.. it's not required for any other gear change.
    Nov 2006
    Quote Originally Posted by dodgeGTI View Post
    You definently dont need to do this in a standard box. I've driven a s2000 and it didn't crunch even when pushing close to 9000rpm.
    I really don't know how you would be driving to manage to get it to crunch. Not having the clutch in all the way??
    It would be interesting to watch you drive - If I were you i'd check out a few youtube vids or jump in a car with someone driving at speed and see if they are doing things any differently.
    Either the box is rooted or The box has ****ed\no synchros and you are shifting slow or you aren't pushing the clutch in the whole way. Thats all the possiblities I've got ???
    My old car did this abit after the synchros on 2nd and 3rd wore out totally (180,000kms), but would only do it when shifting at speed. I remember once I shifted and crunched after it was sitting in 2nd. My heart stopped. Box seemed fine, but I got rid of the car shortly after (Suggesting to the next buyer they replace the synchros!)
    dodgey GTI Guest
    I know it's me, I tried just concerntrating on the sequence, Clutch, shift, release and it was better when I was actually conscious of what I was doing. But, feathering the the throttle mid change to keep the revs up certaily helped.
    Cheers for all your help guys!
    dodgey GTI Guest
    Just a quick note to say thanks to all on this one. I now officially have no problems driving stick!
    Feb 2007
    Quote Originally Posted by dodgey GTI View Post
    Everyone's got a slightly different driving style - I personally tend to stick the clutch in a small fraction of a second before I back off the throttle, which causes the revs to rise about 200-300rpm before I change gears.
    My parents, on the other hand, take a LONG time between gears, in which case the revs drop substantially between gears. Either way, the 'box isn't crunching.
    Neither of us crunch the gears - so I guess it's a matter of "whatever works" Glad you've figured it out.
    Double-clutching is for cars with no syncro its from the dark ages, no need to do this on a modern vehicle
