got any pics of the bits you are talking about?
a little while ago I noticed my RH headlight beam jiggling a bit and it turns out that the retaining tabs are broken from when I hit a little kangaroo - the manual says that you can buy screw on replacements. The headlight does have holes where something can be screwed on
are these replacement tabs available? googling didn't find anything
Make something out of some sheet metal. Cut size measure distance between holes and drill it out and screw it on.
