Why dont you get them off the Whiteline site
Or walk onto Pedders. I have the Pedders ones, which i have been told are the same as Whiteline, but rebranded
OK, I'm confused here.
Powerflex make the PFF85-201 kit for the 9N(3) Polo which also fits the 2WD MkIV Golf (and everything else that is based on this car). This kit has a split bush and no dimensions are available from their website.
On the other hand, SuperPro make the SPF3311K kit for the 9N(3) Polo which has a solid bush but for the 2WD MkIV Golf, they make the SPF1915K kit which has a split bush with slightly different dimensions for everything aside from the outer diameter (30mm).
Meanwhile, Nolathane make the 45599 kit for the 2WD MkIV Golf which has slightly different dimensions again from the outer diameter and nothing for the 9N(3) Polo.
So are the other dimensions (overall/inner length, flange diameter, inner diameter) unimportant?
I'm guessing that the inner tubes will all have the same inner diameter so that the overall inner and outer diameters are identical which would mean that stiffest bushes are probably going to be the ones with the largest bush inner diameter (this assumes that the polyureathane used is of similar stiffness).
What to buy?![]()
Resident grumpy old fart
MODS- TOO MANY
They only list the rear ones (and their bushes are the Nolathane ones)
Oh My bad, didnt notice you wanted the front ones
MODS- TOO MANY
I'm prob being a noob, but is the SEAT item different for that front bush as with the rear? maybe that could be an option
I doubt the SEAT front bushes are any different since the rear ones are just solid rubber versions of the stock ones and the front bushes don't have voids.
Current - 2006 VW Polo TDI & R34 Nissan Skyline GTV+T
Was - 1991 BMW 525i/M -> 1991 CBR250RR -> 1999 Proton GTI -> 1984 Merc 500SEC -> 2006 VZ Commodore SV6 6M -> 1996 R33 GTS Skyline -> 2000 Volvo S80 TT -> 2008 Hyosung GT250R -> 1990 BMW 535iS -> 1997 BMW 540i V8 -> 1986 BMW 535iS -> 1985 Nissan Pulsar SSS...
For Sale - 1986 BMW 535iS & 1986 528i Exec.
