Results 1 to 10 of 16
Thread: Removing Rear wheels
    Sep 2006
    Brisvegas
    The other night when i had a nail in my tyre i ran into a problem. I had the car on a jack, wheel nuts off and already to take the wheel off and when i went to take the wheel off it didnt budge. Now ive had this before where the wheel rusts to the hub, and normally you just give it a tap and it comes off. But this time no, gave it a yank and a kick and nothing. obviously i was carefull of the car coming off the jack and i also had a spare wheel under the car just in case it came down. Anyway i rang VW assistance and they said if nothing i had done worked then the only other thing they suggest is
    "to put two wheel nuts in (opposite sides) so its finger tight, then loosen the nuts a full turn. Then go for a drive if you can in sharp turns and itll break free." This worked a charm, so i just thought i would let you all know in case it happens to you at some stage.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Point Cook, Vic
    sounds like a reasonable way of doing it! although i wouldnt go for too long a drive!
    FOLLOW US ON FACEBOOK
    Sep 2006
    Brisvegas
    Quote Originally Posted by Tim View Post
    Yes i wouldnt recomend a long drive either. I just went in a circle.
    Have a Look
    CUSTOM CODE
    Phase 2
    May 2007
    add to faq!
    Sep 2006
    Tweed Heads
    Hoyhoy.
    You know Shane another idea that will work is more Wheat Bics.
    Hooroo.
    Sep 2006
    Brisvegas
    Yeah i was getting to that
    And eddy your very funny. lol
    Have a Look
    CUSTOM CODE
    Phase 2
    Alfred Cove, WA
    That is such a dodgy recommendation, but effective none the less. I just kicked the top of the wheel really hard and swore. It broke the seal and came off.
    Mar 2006
    South Hobart Tasmania
    Hey Aussie Kids, Thats a nifty idea, better than pulling the car of the jack onto your self.
    Our jack should be know as the widow maker not very stable.
    Sep 2006
    Brisvegas
    Quote Originally Posted by Ben_GTI View Post
    Why is it dodgy. Its not like your going for a cruise or anything. Just a quick drive with wheel on lock. It took me all of 5meters to crack the seal.
    Have a Look
    CUSTOM CODE
    Phase 2
    Nov 2006
    I noticed the "rusty hub" issue recently, so wire brushed mine and gave them a light spray of lithium grease before refitting the wheels. Haven't had the wheel removal problem, though.
