Results 1 to 10 of 13
Thread: Removing Bumper of a GTI - Help Please
    Dec 2007
    South Africa - KZN
    Hi guys,
    I'm going to be installing a water injection kit pretty soon. Need to remove the front bumper so I can plan the installation. Any tips on getting it off? I removed 4 screws in the front wheel arches as well as 4 on the top of the grill but it still wont come off. Am I missing something?
    Any help would be appreciated,
    Thanks
    Current - '07 VW Polo GTI: Candy White, Sunroof, Black Leather with Red Stitching, 200+ BHP
    Previous - '06 VW Velociti: Blue Graphite
    Dec 2007
    South Africa - KZN
    Finally managed to get the bumper off. If theres anybody else out there needing to remove the front bumper of there 9n3 GTI pm me and I'll help you out. If I have some time I'll write a how-to for the newbies like me.
    Nov 2006
    Hunters Hill, NSW
    hey I've broken a foglight in the front, might need to get it off, can you post here?
    Red Polo GTI
    GIAC
    H&R Cup Suspension
    Rear Swaybar
    Mar 2006
    South Hobart Tasmania
    i hope this may help you Cheers rob.
    Dec 2007
    South Africa - KZN
    @PoloGTi - Awesome diagram, wish I had it earlier, would have saved loads of time.
    @Glide_GTI - No need to remove the bumper to change the fogs. For the left fog you can pull of the black plastic surround. You'll notice 3 screws holding it on, you'll need a spline set to get them off. Then just unplug the electrical connector at the back of the fog light. Easy. The right fog is basically the same procedure but the black plastic surround is fastened on by a single screw, once thats off its easy. Btw its interesting to note how much the right fog light obstructs the flow of air to the intercooler.
    Anyway, hope that helps
    Nov 2006
    Hunters Hill, NSW
    thanks guys !
    I wonder how much the lense is, probaby have to buy the whole thing, btw it is the right one
    Red Polo GTI
    GIAC
    H&R Cup Suspension
    Rear Swaybar
    Jan 2008
    Western Sydney
    hey guys, i'm having some trouble removing the bumper to install my honeycomb grills.
    so far i've removed the 4 screws above the upper grill and the 2 screws hidden by the upper grill. also 4 screws in each wheels arch.
    can't seem to find the screws (labeled 2 in above picture)
    any help much appreciated
    Grant
    Nov 2007
    They should be the ones holding part of the bottom engine cover on.
    Somebody correct me if I'm wrong.....
    Dec 2007
    South Africa - KZN
    They aren't really screws, you can pry them off with a flat screw driver. They are small and plastic, i find it easier to feel them than see them. If i remember correctly if you at the front of the car, they concealed behind a little plastic ridge. Slide your hand along the little ridge and you should feel them. Not sure if that makes sense but hope it helps.
    South West Sydney
    Anyone know what this mystery pipe to nowhwere does or is for?
    Simon
