Results 1 to 6 of 6
Thread: Removing Badges
    Canberra
    Removing Badges
    Does anyone know a good method to remove the POLO badges from the rear of a POLO?
    I have removed badges in the past..but never on a POLO...i normally would use a heat gun or hair dryer?
    any suggestions or better ideas?
    08 POLO TDi.Black.Seat adjusters
    Jun 2007
    I did mine a few weeks back.
    I used a heat gun, and fishing wire, a plastic knife. It took a long time, you just have to be careful with it. I heat the back of the badge up, use the fishing wire, and occasionally, used the butter knife as leverage to help "pull" it out..
    Not sure whether this is the best(safest) effort, but it worked for me. You'll also need some adhensive cleaner as well, if you want to get rid of all the glue.
    Mar 2008
    Anstead, Brisbane
    did mine a few weeks ago, just heated with a hair dryer a little, then used dental floss to separate the badge off the car. Then just gently peel off the glue and should be perfect. Needs a good clean to get rid of those last new marks ect but yeah probs took 10min to do.
    Canberra
    Badges successfully removed on the weekend....thanks guys for the suggestions (fishing line worked a treat!!!)
    Jun 2008
    ^POST PHOTOS!!!!
    this post is useless without a photo.
    Jan 2007
    Quote Originally Posted by leasaunce View Post
    ^POST PHOTOS!!!!
    We have an ecomotion for that
