Results 1 to 10 of 10
Thread: "Reluctant" gearbox
    Feb 2007
    "Reluctant" gearbox
    I'm curious whether anyone else has had any issues with getting their Polo's into 1st gear after sitting at idle out of gear for a while?
    It's happened a few times (not many) since I got the car when the gearbox doesn't quite want to go into first - it seems to get "stuck" halfway up the gate and doesn't fully engage.
    Just wondering whether it's an issue I should really get looked at by a dealership - or whether it can be a little reluctant sometimes?
    I've only crunched it once - all other times, I've put the car into second, then into first - resulting in a rather "un-GTI" takeoff
    Sep 2006
    Brisvegas
    Im pretty sure its a safety feature to stop you going from 5th or reverse or something straight into 1st. Mine does it sometimes when i pull up at lights without down changing gears. All you have to do is slip it into second and then back to first.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Feb 2007
    Quote Originally Posted by shaneth
    Cheers mate
    Saved me looking like a goose at the dealership. Now that I know it's not just mine, I'm not worried about it at all, especially since what you said makes sense.
    Sep 2006
    Brisvegas
    Yeah my last car had the same thing so when the polo did it to me the first time i figured it out.
    Have a Look
    CUSTOM CODE
    Phase 2
    We have been working on engine mounts on the little fellows, our first prototypes went in Friday, although too stiff (ie: too much vibration at idle) - the difference in the shifting action is amazingly transformed.
    These things run a cable shift gearbox, and the rear pedulum mount is the same as the one from the 1.2 litre, 40 kw car, so its not realy meant to handle the HP & Torque we are putting through it. The engine can rock just on 50mm at the extent of the arc of travel, the shifter cables are constantly being stretched & compressed in this movement. The poor gearshifter struggles under these conditions!
    Its a difficult engineering issue to fix, but after a couple of months, we almost have it sorted.
    Good news is the mount has settled & the vibration settled down - seems like the mount requires a bit of break in time (like most engine mounts)
    Jul 2007
    Auckland, NZ
    Guy,
    When is this modification going to be completed? I am eagerly waiting for it!
    Jun 2007
    Quote Originally Posted by insanekiwi View Post
    Guy,
    alittle off topic. a friend of mine was telling me that putting synthetic gearbox oil will improve the shifts?? is that true?
    Jul 2007
    Auckland, NZ
    From what I've heard in the past, best to stick with the fluid recommended.
    Only thing I really heard positive was redline gearbox fluid, apparently really good...
    Feb 2007
    Brisvegas
    I have used redline fluid before in the very knotchy toyota sportivo 6 speed gear box. Made shifting a lot smoother even at high revs!
Similar Threads
  1. Speedo Cable vs Gearbox
    By hiho in forum Mk1 Golf
    Last Post: 29-09-2006, 07:24 PM
