Page 29 of 38 FirstFirst ... 192728293031 ... LastLast
Results 281 to 290 of 378
Thread: Red Devil mkII - The Journey Continues
  1. #281
    Jul 2012
    Gold Coast, Qld
    Well done, mate. Can't wait til the next track day!
    Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
    APR Stage 2+ w/RFD | Autotech HPFP | IE CAI + BSH Heat Shield | NPC Clutch + SMF | HPX 3" TBE | CTS FMIC | VWR Short Shifter | Comp Haldex | Uprated Engine Mounts | MCA Red Suspension | HP Superpro LCA/ALK/Ball Joints | Superpro Rear Bushes | AP Racing BBK | P3 Gauge | 16% tint
    Track wheels: 18x8 ET45 Enkei Racing PF01 | Tyres: 245/40R18 Yokohama Advan A050 Soft | Street: 245/35R19 Michelin Pilot Sport 4 S
  2. #282
    Jan 2009
    Quote Originally Posted by Machine View Post
    Bring it on hey.
    You must still be on cloud 9 from your Cootha Classic results - brilliant results dude.
    Daily: 2010 VW Jetta Highline
  3. #283
    Jul 2012
    Gold Coast, Qld
    Quote Originally Posted by seangti View Post
    Bring it on hey.
    Thanks buddy. Yup. It's like a dream. Still can't get over the whole finish line fiasco. If only I'd kept on the throttle...
  4. #284
    Feb 2014
    Gold Coast, Queensland
    Looks awesome mate. Will definitely be a lot more "under the radar" with the wing off. The wheels look great too, they turned out better then I expected
    2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
  5. #285
    Aug 2006
    Melbourne VIC
    I like it!
  6. #286
    Jan 2009
    I ran at lakeside Timeattack last weekend with the car all sorted and optimized from some earlier fiddling with sway bars.
    I ran a best of 63.6, with my best 3 laps within 0.1s of each other. This is 0.5s slower than I'd ran on the previous turbo and previous old tyres. By way of power/peak speed, my silver car would peak at ~178kph, this set-up was 185-188kph and with the previous turbo and tune was ~192-194kph. There is more time in the car, about a second according to my data, so I may eventually get that 62s lap. Based on the analysis and times achieved, I'd say the car is 0.5s slower in the current state of tune.
    The V70 tyres were really good at speed and good under brakes, a little lesser around mid corner on the tighter stuff, they seemed to roll over a bit more than the Bridgestones RE55s did. I ran them to a hot temperature of 34psi. Corner speed was much the same as the old tyres, though I was incrementally quicker in some sectors than when I did the 63.1s lap... The time loss is mostly down to lesser power to get out of the corners and down the straight.
    With the car running well, I decided to run a session without the wing. Yikes, the difference was obvious. I'd say it's much to do with the relatively aggressive rear sway bar set-up I'm running so it's all complimentary at the moment so I've essentially unbalanced it by removing the wing. By just removing the wing, the rear was very twitchy at speed, the car really wanted to pivot and my corner entry speeds were down by 5-10pkh. It was a crazy unnerving to the point that I came in from the session early. Really good validation.
    Off to Morgan Park at Warwick this weekend for a driver training day.
  7. #287
    Dec 2012
    Sutherland Shire, Sydney
    Sounds like you're having a lot of fun!
    I took the newly refreshed red devil back to Lakeside over the week. Since it's last outing I've done the FTG turbo, retune, new front rotors (DBA T3) and new pads (QFM A1RM) and softened the rear sway bar from hard to soft.
    The change of the rear sway bar was probably the biggest change to the detriment of lap time.
    I'd be keen to get opinions on running the front sway bar hard and rear sway bar hard, I think that's my next thing to try. With the rear hard and front soft, it gripped nicely but lacked feel. It was toey/over steery on cold tyres, but ok once hot.
    I'm racing a Nissan Pulsar in the Pulsar challenge and have had to learn fast on this topic.
    Don't go hard on the front (stay soft as possible) - hard will induce more understeer
    A little toe out can help turn in at the track, 0.5 mm toe out (each side for a total of 1 mm) measured at the rims
    (Pain in a$$ doing this to a daily drive for a track day)
    Do go harder on the rear bar (for the track - revert to soft for the street)
    If you get to the point where you are lifting the inside rear tyre off the ground:
    • This reduces load on the outside front - aiding turning
    • Adds some load on the inside front - helps traction during early pulling out of the corner
    Have a think about the sidewall stiffness of the front tyres
    The softer the sidewall is the more negative camber you need
    With the Pulsar (dedicated track car) I'm running -3.5 degrees camber at the front and -3 degrees camber at the rear
    (Obviously you probably can't get anywhere near that - it's just an example showing that negative camber helps heaps)
    On my Skoda Octavia I have the SuperPro LCA's setup with -1.5 deg camber, it has awesome cornering ability!!
    Over 53k of daily usage I've worn out my wonderful Goodyear F1A2 tyres but no unusual wear from the negative camber
    34 psi hot pressure sounds low (FWD needs ~higher pressure) but I don't have any experience or information on your tyres
    We are running the Hankook RS3 (classified as a semi slick) and they like 38~40 psi hot
  8. #288
    Jul 2012
    Gold Coast, Qld
    Love your work, Shorne.
  9. #289
    Jul 2012
    Gold Coast, Qld
    Hankook RS3 is a street tyre and should be run at higher pressure. Sean's running a true semi R compound and 34 hot is properly at the upper limit, if not a tad over.
  10. #290
    Jan 2009
    Quote Originally Posted by Martin View Post
    Thanks for input Martin, always great to hear from another tracker.
    Yeah my current sway bar set-up is back to front on soft and rear hard. It felt really good with the new tyres, with the previous and very old tyres it was good once they were hot, but snap over steery when cold. I had Ken at Accurate Suspension do the corner weighting and geometry, he's renowned up here for setting up a lot of the track cars. I run something like -2.7 camber on the left and -2.2 on the right on the front (I think that's it anyway), can't recall the toe settings and have shims on the rear. I didn't want to run more camber as I drive the car on the street/to work occasionally.
    Re the tyre pressure, as Ben said, being an R compound they start much lower. The fellow at Kumho motorsports suggested running them at 33-34 psi hot as the car is quite light. For a heavier car, he'd run them less.
