Originally Posted by
seangti
I had Paul Stokell co-pilot for a few laps, his feedback was to stiffen up the rear sway bar to dial out some understeer (along with putting in an LSD). I feel the understeer was more pronounced at Morgan than I've experienced recently at Lakeside, perhaps primarily the tyres, but could also be the slower corners. Front downforce wouldn't go astray either.
You can run with a "looser" rear end at a slower track to help it point but it can get scary very quickly at a track with fast sweeping bends. I don't know much about Morgan Park but it doesn't look like you'd be going fast enough to get much downforce without a huge splitter.
LSD? Yeah, we all want one (except Eddy since he has that covered)
Resident grumpy old fart
