LIKE, 10characters
**** FOR SALE **** $12K
Hi,
As Anthony had decided to part with the Red Devil, I saw it an opportunity to buy the car for regular track work.
I'd been teetering with the idea of buying it over a few months when he first announced selling. I gave in to the idea after a track day where an RX7 and GTR punched the wall. Plus I have plans on lots of track time this year, so rather than dump money into the current silver one, thought it's money better spent sitting in an already exceptionally well built car. I'd initially considered it as a daily, but rather than soften it up and detune to make it more streetable for my requirements, I thought it'd be a waste of the hard work that's gone in to it, so will keep flying the track oriented theme.
On the immediate horizon is getting baseline performance figures; 0-100kph, rolling speed intervals, lap times at he local tracks and quarter mile. I'll share that once compiled.
RE mods, before track time next weekend I will soften up the front sway bar to dial out some understeer / promote more movement in the rear. Though will be replacing the coilovers in the next month or two, likely to H&R or KW's. I also an expect an LSD will be needed, have done some research and likely to be wavetrac, will get some track time in it first before committing.
Build on the car when I took delivery.
Enough waffling, I'm now sporting two Polo GTI's.
Current Spec - Nov 2017
VAGAutowerks custom tune
3” cold air feed ducting
Modshack VTDA with custom cold air 3” ducting inlet with K&N pod filter
Custom alloy 3" MAF housing
Custom 3" turbo inlet pipe
Removed June 2015 Billet Turbo Ko3s Hybrid turbo with ceramic ball bearing conversion with Forge adjustable spring turbo actuator - yellow spring
FTG K04-001 with upsized wheels (62.3mm compressor, 46.4mm turbine wheels) with Forge adjustable spring turbo actuator. refer page 26+ for info and pics
Forge Motorsport 007P closed loop diverter valve with yellow spring rated 15-23psi
SEAT Sport intercooler - dual pass core
Custom pipe work - 2" hotside, 2.5" coldside to TB
Removed November 2014 ATP turbo hiflow exhaust manifold HPC coated - as it cracked. Running standard Manifold.
Custom stainless steel 3” dump pipe with 4" expansion chamber & Magnaflow 100 CEL catalytic converter
Custom 3" stainless steel catback exhaust with Magnaflow resonator & 6" round muffler with 42DD 4" outlet
Phenolic intake manifold gasket
ECS lightweight crank pulley
42 Draft Design Ultimate catch can with Morosso exhaust valve and PCV delete - currently removed
SAI Pump, N249 & N112 delete
Wahler 71c thermostat
Genesis II 500cc injectors
Bosch 3 bar FPR
APR high performance in tank fuel pump
Verdict Motorsport O2J aluminium shift bracket bushings
42 Draft Design aluminium shift cable bushings
Deka lightweight ETX14 battery 12lbs 5.4kg
Braille aluminum battery mount
NKG BKR7EKT spark plugs
Superpro sports dog bone bush
Vibra-Technics Gearbox mount
Vibra-Technics Engine mount
Audi A3 custom drive shaft
Sachs 228mm duty clutch plate
Sachs clutch pressure plate
ECS 14lbs light weight flywheel
Wavetrac LSD and rebuilt gearbox April 2016
Wiechers steel front strut brace
Ultra Racing front lower control arm brace
Ultra Racing rear lower brace
Ultra Racing middle lower brace
Whiteline adjustable front sway bar 22mm
Whiteline adjustable rear sway bar 20mm
Whiteline rear shim kit +3mm toe in reduction
H&R Coilovers (20-50mm lower) with Kmac adjustable camber and castor tops
Superpro anti-lift poly rear control arm bushes
Brembo 4 pot front brake calipers
QFM A1RM front
DBA 4000 312mm front slotted rotors
Audi TT rear brake calipers with VW Bora V5 All-wheel drive brake calipers
Lucas/TRW rear brake pads
RDA 256x20mm ventilated rear slotted rotors
HEL braided brake lines
Track: Enkei RPF1 17x8, 35ET, 15.5 lbs 7kg
225/45/17 Yoko AO50 Soft
Daily: Audi TT 17"
Federal RSRR215/40R17
MK5 Golf alloy steering wheel inserts
SWG air vent pod
Prosport Evo electronic boost gauge
Prosport Evo electronic EGT gauge
Prosport Evo electronic air fuel gauge
Ford Focus RS bonnet vents
APR Performance GTC-200 48" SCCA Spec. carbon fiber rear wing
Rear bumper valance delete with JMF alloy bumper diffusers
Sharan antenna
Badgless upper honeycomb grille
Fog lamp delete
Side skirt delete
Lap times (Official - natsoft):
Lakeside, QLD: 1:03.18 (on old turbo at 22psi, RE55s tyres)
- 1:03.2 (FTG turbo at 16 psi, V70 tyres)
- 1:02.99 (FTG turbo at 16 psi, V70 tyres, Wavetrac LSD)
- 1:02.86 (FTG turbo at 16 psi, Federal RSRR tyres, Wavetrac LSD)
Queensland Raceway
Sprint configuration - 1:00.596 29/09/18
Clubman configuration - 1:04.372 29/09/18
National circuit - 1:28.113 29/09/18
Sportsman Circuit - 1:01.913 29/09/18
19 Sept 2020
Sprint configuration - 1:00.274
Clubman configuration - 1:04.082
National circuit - 1:27.58
Sportsman Circuit - 1:01.677
Wakefield, NSW: 1:12.4 (on old turbo, RE55s tyres)
Daily: 2010 VW Jetta Highline
** All information I provide is probably incorrect until validated by someone else **![]()
Looking forward to seeing this car on the track Sean.
Congrats on the purchase and I'm sure the car will be something pretty special when your finished with it![]()
So much win coming soonNice pics too!
MINI Cooper S Clubman - FWD
Can't wait to see this thing on Saturday's Happy Laps.
