Page 9 of 38 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 378
Thread: Red Devil mkII - The Journey Continues
  1. #81
    Jan 2011
    Brisbane - QLD
    Heasmans also fixed mine using swivel plate / ruler equipments. No computer involved, just pure skills and expertise.
    MINI Cooper S Clubman - FWD
  2. #82
    Jan 2009
    Thanks for the input guys. The subframe could make sense so will explore.
    Nat, where is Heasmans? I can only find details for them in sydney.
    Troy, the plan is to reinstall the Kmac's, perhaps will happen sooner as a strut top bearing on the silver car is clunking. I'm yet to contact Kmac for the suspension tops.
    Stuwey - you're exactly right about them going purely by numbers. The guy road tested it, gave the keys back and said it steers to the left. I asked him to clarify before I left and he blamed potentially worn engine mounts and control arm bushes - which is BS as they are all near on brand new.
    The rear has the whiteline shims which change the toe by 3mm. I'd have to look at the figures again, at face value it seemed ok.
    Daily: 2010 VW Jetta Highline
  3. #83
    Southern Highlands
    I'm involved with a dedicated track car and we have heaps of problems getting a correct wheel alignment done by tyre shops and the like.
    Now we only use dedicated motorsports people like VSports here in Sydney who do the whole alignment including alignment, ride height and corner weighting. Makes a HUGE difference to the way the car handles, brakes and wears its tyres.
    Spend some time and seek them out in your city, but you wont get this type of setup for $100. You pay for what you get.....
  4. #84
    Aug 2007
    Cant agree more here . Spent Yrs during my app doing quattros etc and took hrs, not toe and go $100 would get you nothing. Its specialised man, cant stress it enough.
    Alba European
  5. #85
    May 2012
    Go see Ken @ Accurate Suspension.
  6. #86
    Southern Highlands
    Yes, and I cannot stress enough that getting the correct ride height AND corner weighting WILL balance the car better = better lap times.
    You will then be able to play with tyre pressures more accurately. R spec tyres DO NOT like to be over pressured and I have not seen any that run more than 36-38 psi HOT. As mentioned previously, just ask the tyre dealers out at the track, their more than willing to help even if your not a customer....
    VI Gti - weekender
    Caddy Tdi - daily
    TBA - track car coming soon....
  7. #87
    Jan 2009
    Quote Originally Posted by 39erman View Post
    Thanks for your input. I'll go see Accurate Suspension today, Ken is renowned for his work, so good place to start for my humble ambitions.
    I took the alignment sheet to another tyre place who've done a good job on my other car, they said the settings look all good and the aligner previously worked for them and they rate his knowledge highly. Could be a corner weighting issue, I know it's not sitting perfect atm.
  8. #88
    Southern Highlands
    Quote Originally Posted by seangti View Post
    Corner weighting is not hard as long as you have adjustable spring platforms on all corners of the car. If not it can be quite time consuming. You can do some pre height adjustments at home by deciding on your preferred ride height and using a rule or tape measure from the same spot on each corner of the car. Try to do this on a relatively flat surface otherwise you'll just end up jacking up on corner more than another. With this done it will change all your previous wheel alignment settings so then it's off to the wheel aligner.
    Also, if you have stabliser bars, make sure than when the car is at its preferred ride height that none of the uprights/links are tight or binding as this will corner jack the car and transfer load to the opposite side. You should be able to discount the upright/links freely when the car is fully wheel aligned/corner weighted.
    Then go out and enjoy....
    VI Gti - weekender
    Caddy Tdi - daily
  9. #89
    Jan 2009
    I've decided to book the car in with Accurate Suspension for next week. They're also going to fit the Kmac adjustable strut tops so will dial in some camber and castor, along with corner weighting. As I still want to drive the car on the street I'll probably go with -2 to -2.5 deg camber. They aren't hugely fond of the Kmac gear, but for the polo there is little option.
    Bring on timeattack in October, champing to get out there and give it a hot go.
  10. #90
    Sep 2006
    I am running full negative camber which is around -3 or more for street, im going to get another alignment done soon, will be interesting to compare notes
    Do you know how much corner weighting is ?
    MODS- TOO MANY
