I mounted a 2mm thick aluminium bar, bent into to line fairly closely with the floor contour, using the passenger front rail bolts and this has 2 6mm holes in it which I used to bolt in a piece of right angle aluminium which has the extinguisher bracket mounted to it.
That way, the bar under seat stays installed and doesn't interfere with the seat or drawer but the rest is easily removable for daily use.
I'll try to get a picture of it up.
![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
seangti
Running front sway bar on soft and rear medium. Could go hard on the rear for track work to get marginally better front end turn. The rear was very stable through the kink at pace, must be wing Ant.
![Smile](https://www.vwwatercooled.com.au/forums/images/smilies/icon_smile.gif)
I've actually found stability under (heavy) brakes to be the bigger issue than mid corner so long as I don't pike out and lift off after turn in.
Resident grumpy old fart
