Page 31 of 38 FirstFirst ... 212930313233 ... LastLast
Results 301 to 310 of 378
Thread: Red Devil mkII - The Journey Continues
  1. #301
    Rolled the arches at both ends, but it's down to how low you intend to go.
  2. #302
    Jan 2009
    Quote Originally Posted by Julzaac View Post
    I noticed you had: Enkei RPF1 17x8, 35ET which are the exact wheels I want to go. Did you require any rolling or did they fit stock? I know Louis has the 16x7s and they are okay, just not sure about the extra width.
    FYI running stock suspension / brakes (for the time being
    Yeah as Gavin said, the guards have been rolled. I also have TT rims which are also 8", though I can't recall the off set. On my other polo that don't scrub either - I haven't tried the enkei on it. I'm not sure how much impact the rolling has had. The current ride height is relatively high (for a "lowered" car), I also had to raise the front a little for the semi slicks as they are a 215/50/17 and just touched the wheel well on the front under compression.
  3. #303
    Jan 2009
    I've been a bit quiet in this thread as the car's been running well and I haven't fiddled with or broken anything, win.
    I ran at eastern creek back in February and lakeside timeattack round 1 in early March. The car was faultless for the 2500km round trip to Eastern Creek, Nowra (for work) and back.
    As the car is running well, I've got itchy hands so pulled the gearbox out over the Easter break and it's now at NA Autosports having the box opened up for an LSD to be installed. I was planning to run a Wavetrac diff though am being encouraged to consider going a clutch plate diff instead. NA are sourcing prices for me at the moment. I think the Wavetrac will be adequate, I'm aware of the shortcomings of such a torsen diff, so it'll probably come down to the price difference. I know the plate diffs are much better for what I'm doing with the car, though they also come with more maintenance considerations and being clutch oriented, have wear considerations so will need to better understand that too.
    Daily: 2010 VW Jetta Highline
  4. #304
    nsw
    I'll be interested to hear what decision you make re the diff Sean. A mate is making the same decision for his RS clio and i'll probably do a 5 speed diff down the track too. I've attached articles by a US suspension guru regarding full race setups for FWD'ers and other stuff on diffs, that might have something lurking in there that helps.
    April 2000 suitability of preloaded clutch diffs for FWD
    April 2000 longevity of preloaded clutch versus worm drive diffs
    April 2000 all the diff types (rear wheel drive angle on it though)
    I know he's done some articles where he talks about the effect of traction control on clutch pack diffs. From vague memory it was something about how slip needs to develop before the locking will ramp up, so you need to drive them with the TC off or they won't work properly. Might be worth looking into. Eddy seems to drive his on two wheels - wonder what diff he's running?
  5. #305
    Dec 2012
    Sutherland Shire, Sydney
    I have a Quaife torsen LSD in my Pulsar (dedicated track/race car)
    and a Cusco clutch pack LSD (80% locked) in my 350Z
    The Torsen diff is just wonderful - does a marvelous job on the track and yet it's easy to park in the pits
    I do avoid hitting the curbs to keep both wheels on the ground
    Uses normal gearbox oil - no friction modifier - no wear and tear - oil stays clean
    All the other guys have welded up their diffs - that has given them some turn in under steer and when parking in the pits it's a nightmare (real problem pushing them also)
    The 350Z is a pain, parking and left turns always have chirping from the tires and banging from the diff
    Have to use the extra high viscosity oil with the friction modifier
    The clutch plates make the oil black
    The clutch plates will wear out
    For street and occasional track work I would much prefer a Torsen diff
    (I'm now running -4.6 degrees camber on the Pulsar!)
  6. #306
    nsw
    My mate in his clio is leaning towards the quaife too for that (more streetable) reason. Out of curiosity Martin is your pulsar set up so that its inside rear will hover in the air through corners?
  7. #307
    Jan 2009
    Big thanks for the input guys. Sam, I'll have a read through those articles too.
    The ramp angles on the plate diff have to be quite low (which results is lower bite) for FWD for the reasons Martin mentioned. I was advised the car would still have some inside wheel spin as a result of the steeper angles, plus it makes it more gentle on the engagement and the gearbox itself. I run with traction control off, so that part isn't an issue - I hadn't heard that, but I can understand why it would be a hindrance.
    I believe Eddy run a plate diff too nowadays. I vaguely recall he had ran a torsen diff in the past.
    Any reason why Quaife over Wavetrac. I really haven't looked much at the others.
  8. #308
    Dec 2012
    Quote Originally Posted by seangti View Post
    They are both totally awesome
    MFactory also make torsen diffs for a range of cars, they are much cheaper
  9. #309
    Dec 2012
    Quote Originally Posted by sambb View Post
    I really don't like the VAG fake LSD (using the brakes)
    Previously I thought that the clutch pack was the best option
    Now I am totally adamant it's torsen for street usage
    Motorsport can use either - hard core and drifting need the clutch pack
    Ok - that's an interesting point
    I have not specifically set my car up to do that - but as my driving speed has increased and my setup has changed to go harder - yes, my car does pick up the inside rear wheel - but not big air like the other guys, it's only a fist of the ground
    With 60% weight at the front, there are particular corners and speeds where the inside rear wheel will come off the ground - that's just how it is
    Even the Nissan GTR LM was picking up it's inside rear
    As you go for a stiffer rear sway bar that increases the tendency to pick up the inside rear
    It's not necessarily a bad thing (on FWD), it has a subtle/moderate benefits:
    -helps put some weight on the inside front (to keep it on the ground - and if you have a torsen diff this is important)
    -helps limit weight on the outside front wheel, which reduces under steer
    The thing is if you dramatically lower a FWD car with McPherson strut suspension, that wrecks the front geometry
    It moves the roll center away from the center of mass and causes more roll (rather than less)
    Cars like this pick up the inside rear wheel with big air time
    But they also get nasty bump steer and erratic handling
    My car has a higher than average ride height on the grid - yet it is ~15mm lower than stock
  10. #310
    nsw
    "-helps put some weight on the inside front (to keep it on the ground - and if you have a torsen diff this is important"
    Glad you mentioned that. That's what I could gather too, that to run the torsens in FWD it would help to have that kind of setup to ensure BOTH your fronts were being pressed into the ground to make the diff work properly. My open diff car was definitely way quicker on the tight tracks I'm normally on when set up this way at least allowing me to run without the interference of the TC/power cut.
