Well done, mate. Can't wait til the next track day!
Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
APR Stage 2+ w/RFD | Autotech HPFP | IE CAI + BSH Heat Shield | NPC Clutch + SMF | HPX 3" TBE | CTS FMIC | VWR Short Shifter | Comp Haldex | Uprated Engine Mounts | MCA Red Suspension | HP Superpro LCA/ALK/Ball Joints | Superpro Rear Bushes | AP Racing BBK | P3 Gauge | 16% tint
Track wheels: 18x8 ET45 Enkei Racing PF01 | Tyres: 245/40R18 Yokohama Advan A050 Soft | Street: 245/35R19 Michelin Pilot Sport 4 S
Daily: 2010 VW Jetta Highline
** All information I provide is probably incorrect until validated by someone else **![]()
Looks awesome mate. Will definitely be a lot more "under the radar" with the wing off. The wheels look great too, they turned out better then I expected![]()
2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
I like it!
I ran at lakeside Timeattack last weekend with the car all sorted and optimized from some earlier fiddling with sway bars.
I ran a best of 63.6, with my best 3 laps within 0.1s of each other. This is 0.5s slower than I'd ran on the previous turbo and previous old tyres. By way of power/peak speed, my silver car would peak at ~178kph, this set-up was 185-188kph and with the previous turbo and tune was ~192-194kph. There is more time in the car, about a second according to my data, so I may eventually get that 62s lap. Based on the analysis and times achieved, I'd say the car is 0.5s slower in the current state of tune.
The V70 tyres were really good at speed and good under brakes, a little lesser around mid corner on the tighter stuff, they seemed to roll over a bit more than the Bridgestones RE55s did. I ran them to a hot temperature of 34psi. Corner speed was much the same as the old tyres, though I was incrementally quicker in some sectors than when I did the 63.1s lap... The time loss is mostly down to lesser power to get out of the corners and down the straight.
With the car running well, I decided to run a session without the wing. Yikes, the difference was obvious. I'd say it's much to do with the relatively aggressive rear sway bar set-up I'm running so it's all complimentary at the moment so I've essentially unbalanced it by removing the wing. By just removing the wing, the rear was very twitchy at speed, the car really wanted to pivot and my corner entry speeds were down by 5-10pkh. It was a crazy unnerving to the point that I came in from the session early. Really good validation.
Off to Morgan Park at Warwick this weekend for a driver training day.
Sounds like you're having a lot of fun!
I'm racing a Nissan Pulsar in the Pulsar challenge and have had to learn fast on this topic.
Don't go hard on the front (stay soft as possible) - hard will induce more understeer
A little toe out can help turn in at the track, 0.5 mm toe out (each side for a total of 1 mm) measured at the rims
(Pain in a$$ doing this to a daily drive for a track day)
Do go harder on the rear bar (for the track - revert to soft for the street)
If you get to the point where you are lifting the inside rear tyre off the ground:
- This reduces load on the outside front - aiding turning
- Adds some load on the inside front - helps traction during early pulling out of the corner
Have a think about the sidewall stiffness of the front tyres
The softer the sidewall is the more negative camber you need
With the Pulsar (dedicated track car) I'm running -3.5 degrees camber at the front and -3 degrees camber at the rear
(Obviously you probably can't get anywhere near that - it's just an example showing that negative camber helps heaps)
On my Skoda Octavia I have the SuperPro LCA's setup with -1.5 deg camber, it has awesome cornering ability!!
Over 53k of daily usage I've worn out my wonderful Goodyear F1A2 tyres but no unusual wear from the negative camber
34 psi hot pressure sounds low (FWD needs ~higher pressure) but I don't have any experience or information on your tyres
We are running the Hankook RS3 (classified as a semi slick) and they like 38~40 psi hot
Love your work, Shorne.
Hankook RS3 is a street tyre and should be run at higher pressure. Sean's running a true semi R compound and 34 hot is properly at the upper limit, if not a tad over.
Thanks for input Martin, always great to hear from another tracker.
Yeah my current sway bar set-up is back to front on soft and rear hard. It felt really good with the new tyres, with the previous and very old tyres it was good once they were hot, but snap over steery when cold. I had Ken at Accurate Suspension do the corner weighting and geometry, he's renowned up here for setting up a lot of the track cars. I run something like -2.7 camber on the left and -2.2 on the right on the front (I think that's it anyway), can't recall the toe settings and have shims on the rear. I didn't want to run more camber as I drive the car on the street/to work occasionally.
Re the tyre pressure, as Ben said, being an R compound they start much lower. The fellow at Kumho motorsports suggested running them at 33-34 psi hot as the car is quite light. For a heavier car, he'd run them less.
