Originally Posted by
39erman
Probably near their life's end, id say. Tyres are too old and the compound and case structure of an '08 tyre is no where near the current tyres. Yoky A050R are about the best there is today. Great grip, right down to the canvas and good life. We find that the A050R's only loose about .6 sec from new to ****ed!
Just gotta pressure them right, setup the car to suit the very stiff side walls and when not in use keep them in a dark place....
The A050R is supposed be an upgrade of the A048R which handles heat cycles better but despite comments I've read of the A048R's going off quickly, mine have held up well over the past 2.5 years of use (about 10 events). In fact, in the last 3 track events, I've set 2 PB's and almost set another PB in the 3rd (which I was trying NOT to do since this was a regularity event).
I'd be more concerned about the possibility of the older tyres delaminating as the rubber hardens and loses its bond to the casing - I had 2 old stock A048Rs fail on me before I bought my current set of fresh stock tyres.
Resident grumpy old fart
