Results 1 to 10 of 10
Thread: Rear wheels stuck!!!
    Oct 2009
    new south wales
    Hey guys,
    Just thought I'd share this with you. Went to rotate tyres yesterday and upon trying to remove the rear left, realised it was stuck solid. Doesn't matter how much I swore and kicked, no movement. Got online that night and searched for remedies, found that sheer brute force was the only option. Double checked with a couple of tyre places this morning, same answer (heavy rubber mallet, block of wood etc.).
    So tried again this morning, and using a metre long 4x4 started bashing the inner side of the rim/tyre (rotating as I bashed). Half and hour later, the wheel came off. The same process was needed for the right rear.
    It seems as though that little bit of water that penetrates through to the hub had caused some rust/oxidation and fused wheel to centre of hub. Just sanded it back and applied copper based anti-sieze.
    I'm glad I found this out before I ever had a puncture, or I'd be proper stuffed. So if you have never removed your wheels, especially the rear, please check...
    May 2010
    braidwood n.s.w
    good work.we get a few of them at work.i know its a pain in butt.
    Nov 2010
    Burpengary, Queensland
    I was going to add my comment here but realised I have a Golf not a Polo. So for fear of upsetting mods, I will keep my comments to myself.
    May 2010
    S.E Melb
    lol then why did u comment?
    thanks for the heads up, was planning to rotate mine today but had a change of plans, so now, tomorrow ill be prepared!!
    MY07 Polo GTi
    Last run - 114.8kw atw
    Winton - 1:52.7130
    Oct 2009
    Templestowe, VIC
    The easiest way to remedy this (and apparently VW themselves advise this) is to loosen off the bolts but leave them in place, and drive the car in slow circles, or just move the steering wheel sharply left and right while driving or reversing at slow speed. Don't totally remove the bolts though or you might have some trouble!
    MY11 Skoda Octavia vRS wagon 147TSI DSG
    Feb 2008
    When you put them back on, put some grease or anti seize on the wheel hub to prevent it from happening again.
    Oct 2009
    new south wales
    Quote Originally Posted by tooch View Post
    I actually tried this, but since it didn't work I chose not to mention it...
    Aug 2007
    Rubber mallet whilst the wheel is being spun works for me every time and has done for the last, well 20 odd years. Yeah copper grease and a good sandpaper for the win
    Jmac
    Alba European
    Nov 2010
    Quote Originally Posted by hazrd View Post
    Look a bit harder, I didn't comment
    Oct 2009
    Templestowe, VIC
    Quote Originally Posted by GTI_PAPA View Post
    Worked for me and other people, and may help others in future. Hence I mentioned it.
