Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: rear damper repacement
    nsw
    Righto thanks for that, i'll check out DPM. The only other thing I might consider since it comes in at the same price is the weitec F sport kit (springs/dampers) - 15mm drop, with weitecs own dampers, but I can't get any info out of them on spring rates so don't know where they fit in relative to eibach pro kit etc, and I can't seem to find much feedback on that kit.
    generally so far I seem to be finding that koni yellows on the softest settings are going to suit softer spring rates better than bilstein B8's which might over damp things and be overkill.
    Quote Originally Posted by noone View Post
    cheapest option could be one of many, normally Euroupe. DPM Performance is a good place to start, fair shipping I've found.
    I say coilovers as I don't believe there to be much difference on our car between coilovers and strut / spring combos accept the perch height can be changed. If you want adjustment, lots of options. If you want stock height, should be fine. Definitely right about the uprated springs.
    Happy to show you how my car is setup if you're interested, a nat park run over xmas could be good.
    Have a look at PSItuning too Sam. Link in my signature.
    Cheap, Fast, Reliable. Choose two.
    Have a look at overseas/ebay for the Koni STR.T shocks.
    Sachs/Boge may also have replacements
    http://www.ebay.com/itm/Boge-Rear-Sh...item27da41c056
