Results 1 to 10 of 13
Thread: Rear camber question
    Feb 2007
    Brisvegas
    Wondering if anyone else had come across this?
    After I got the new coilovers fitted I noticed pretty bad tyre wear on the inside of both rear tyres for the first time.
    I had the rear lowered pretty far with guard on tyre. I was told that dropping it so far would naturally cause more camber and that's why the insides of the rear tyres have scrubbed out.
    Thoughs??
    Oct 2010
    Melbourne, VIC
    Yep, you need camber shims to correct this.
    VWVortex.com - DIY: Rear Camber Shims
    You can make 4 U shaped individual shims from different thickness of metal sheet to avoid having to remove the hub
    Resident grumpy old fart
    Feb 2007
    Brisvegas
    Thanks mate! What brand shims would you recommend?
    Oct 2010
    Melbourne, VIC
    No idea! I've seen Eibach ones mentioned. http://www.rtecshop.com/shop/suspens...mk4-94-07.html
    My mechanic was going to do the homemade shimming with mine except it all measured Ok on the wheel aligner.
    Aug 2007
    Quote Originally Posted by kaanage View Post
    Yep a natural effect when you drop the car, in natural state they can tend to scallop as does most of the brand, with tyre rotations minimising this well extended the wear period really. Depends on what you want the car to do to mate, you are doing more track work now, you still want a bit of negative camber for handling and of course keep the rear toe right too, then after the rear is adjusted it naturally knocks all the front out so itll all need adjusted too. Nice to get tyre wear down though.
    Jmac
    Alba European
    Feb 2007
    Brisvegas
    Thanks Jimmy! Will do mate.
    Sep 2006
    Tweed Heads
    Hoyhoy.
    We're talking about a rear beam axle, are we not.
    Hooroo.
    Aug 2007
    Quote Originally Posted by Eddy View Post
    Hoyhoy.
    Yeah totally mate, which is normally an non adjustable unit, thats pretty much why you have to shim it. The Red Polo is eating the inside with too much negative. have you touched your beam eddy? i know you have put a lot into the front.
    Jmac
    Alba European
    Sep 2006
    Tweed Heads
    Hoyhoy.
    I have done a few things to the rear, which helped on the track >
    Rear strut brace.
    Rear sway bar.
    Rear toe out shims.
    It seems strange that Anthony is wearing the inside on the rears, I never had that problem, the main problem was on the track scrubbing in the opposite direction until the shims went in.
    The standard toe in on the rear is huge.
    Hooroo.
    Oct 2010
    Melbourne, VIC
    He may have lowered his car more than you have, Eddy. Normal cars tuned for track performance often sit surprisingly high to the streeter/JDM type crowd.
