Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Rear camber question
    Aug 2007
    Quote Originally Posted by Eddy View Post
    Hoyhoy.
    I have done a few things to the rear, which helped on the track >
    Rear strut brace.
    Rear sway bar.
    Rear toe out shims.
    It seems strange that Anthony is wearing the inside on the rears, I never had that problem, the main problem was on the track scrubbing in the opposite direction until the shims went in.
    The standard toe in on the rear is huge.
    Very true about the toe Eddy, i agree, anthony i reckon what you need to do is get it on the gauges and get a picture of where all the angles are at, remember you have toe shims already. Then take it from there.
    cheers
    Jmac
    Alba European
    May 2011
    Albury, NSW
    Hey guys - just digging this up from the past - erm I'm thinking long term here, but I want some camber on show wheels I'm going to rock next year. They're 8.5" wide on the back (7.5 fronts) and ET26 so I reckon they'll poke and I want to get them under the guards. So If I buy some Eibach Camber shims - how many sets do I need and what do I do with them lol? No idea about any of this stuff. Also can I just put them in for a show and take them off again without getting re-alligned? Don't care about allignment for a weekend, but for anything else I do
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Oct 2010
    Melbourne, VIC
    You could just loosen off the hub mounts and put thick or multiple washers between the hub and the mount for the lower studs.
    Alignment will be crap since the lower studs aren't parallel to the ground but you'll get the "tuck" you're after.
    After removing them, alignment should be as before.
    Resident grumpy old fart
