So what are you running exactly? The Bora calipers on a stock rotor? That doesn't sound right being the bora calipers would be designed for a vented rotor, not a solid (and skinny) polo rotor.
What fronts do you have, stock?
The stock sized stuff even with DBA rotors and good pads aren't what I'd call authoritive. Add some braided lines, bigger rear is nice. Gavin and Louis both have 312mm fronts, I've ran Gavin's car on the track, it stops well, similar pedal travel to stock, so good modulation and much better at high speed over stock. It's not brembo, but ample competent.
