Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 61
Thread: Rear brake upgrade
  1. #21
    Jan 2009
    Quote Originally Posted by rgvlee View Post
    I'm more thinking of doing it 'because I can'
    lol, no further justification is required.
    Make it happen
    Daily: 2010 VW Jetta Highline
  2. #22
    nsw
    then we did well and truly hijack. sorry mate.
  3. #23
    Nov 2012
    WA
    Well they were lot closer than I thought, trackday yesterday finished them off.
    Will try to source on Monday otherwise I'll have to throw stock gear on.
    Chasing some early audi tt leads.
    There is a thread on another forum listing rotor sizes for the various models that fit mk4 golfs, I'll post up the details later interesting reading.
    08 9n3 Polo GTI
    Mods: heaps
  4. #24
    Oct 2010
    Melbourne, VIC
    Sorry to all who may have thought i was saying a bbk is a waste of money. It does have real benefits in the right circumstances but I'm trying to put the focus on where these real benefits are as opposed to what some people may assume without thinking through the underlying physical factors and limitations.
    Rgvlee, that's as good a reason for the upgrade as many of the things we do. Eg last night I used a trim sealant on my tyres and the nut caps.
    Resident grumpy old fart
  5. #25
    Dec 2012
    Sutherland Shire, Sydney
    On a Polo there may not be enough rubber on the road to gain a lot more braking but I would still expect more capable braking with lower pedal pressure
    On my Octavia I have 6 piston calipers and 357mm floating rotors - with good rubber ( Goodyear F1A1 225/40/18 ) it certainly brakes significantly harder than a standard Octavia
    (In order to get that extra braking I had to get into VCDS and set the anti lock braking to low/late because the car could now brake harder/faster than the onboard computers though was possible)
    Around town and during rush hour driving it's less fatiguing because much less brake pressure is required - yet modulation control is still good
  6. #26
    Nov 2012
    WA
    This is the thread I was talking about
    The Mk4 Brake Upgrade - Sizes/Info
    Heres all the brake sizes on the VAG range, and what they are fitted to as standard.
    VW Golf R32 | Audi TT 3.2 Quattro
    The Front brakes are 334mm x 32mm Vented 2-piece Discs, Twin piston(32mm/42mm) calipers
    The Rear brakes are 256mm x 22mm Vented Discs, 38mm Lucas singles
    Seat Leon Cupra R
    The Front brakes are 323mm x 28mm Vented (grooved/drilled option) discs with 4 piston(34/38mm) Brembo calipers
    The rear brakes are 256mm x 22mm Vented , with 38m Lucas single piston calipers
    Audi TT-Quattro (225hp) | VW Golf anniversary | Golf GTI AUQ | Skodá Octavia VRS | VW Golf V5 170 | VW Golf V6 4 Motion
    The Front brakes are 312mm x 25mm Vented Discs, 54mm ATE single piston calipers
    The Rear brakes are 256mm x 22mm Vented Discs, 38mm Lucas single Piston calipers
    Audi TT (180hp)
    The Rear brakes are 232mm x 9mm Solid Discs,
    Golf GTI 1.8T | Golf 130/150 TDI | Golf V5 150 | Seat Leon 130/150 TDI and 20VT
    The Front brakes are 288mm x 25mm Vented Discs, 54mm ATE single piston calipers
    Golf 2.0 8v | 1.8 | TDI 115 | TDI 110 | TDI 100 | TDI 90
    The Front brakes are 280mm x 22mm Vented Discs, Single piston calipers, caliper carrier integrated into hub (FS III's)
    The Rear brakes are 232mm x 9mm Solid discs
    Golf 1.4 16V | Golf 1.6 16v | Golf 1.6 8v | SDI
    The Front brakes are 256mm x 22mm Vented Discs, single piston calipers, carriers integrated into hub (FS III's)
    I've managed to locate a front and rear set off a 99 TT quattro but unsure if they'd fit. I think that's the 225hp model.
    08 9n3 Polo GTI
    Mods: heaps
  7. #27
    Nov 2012
    WA
    OK I've managed to find a set of calipers off a 2000 S3 as well.
    What's the best way to ensure any of these will fit? They are all on the otherside of the country so I can't pop in an check before I hand over coin.
    08 9n3 Polo GTI
    Mods: heaps
  8. #28
    Nov 2012
    WA
    The 2000 S3
    or 99 TT quattro?
    or Both?
    Both are about the same price.
    And yeah I'm onto the calipers and carriers.
    When ordering rotors/pads, do you just order them for a 2000 S3?
    08 9n3 Polo GTI
    Mods: heaps
  10. #30
    The 2000 S3
    or 99 TT quattro?
    or Both?
    They are both the same Lee.
    If you get pads from GSL/Brakes Direct Matt knows what you need. Otherwise, correct S3 pads.
