I am in exactly this boat. Keen to follow. Maybe combine shipping.
My rears are up for replacement soon so before I go off ordering rotors and pads let talk rear brake upgrades.
I was surprised to hear how little it cost to go bigger on the fronts. Are the rears the same?
I've done a quick search and found some talk of 256mm setups off of a couple of cars, S3, TT etc
Anyone done it?
Specifically what to look for? Model, year etc
08 9n3 Polo GTI
Mods: heaps
Mk 7 R Wagon Wolfsburg. APR Stage 1. Removable towbar.
256mm upgrade is easy enough. It all bolts on, you'll just have to cut down the backing/dust shields.
Just beware that you'll need 2wd parts - the carrier offset is different from the Bora 4Motion gear.
Cheap, Fast, Reliable. Choose two.
So I just need the carriers and larger rotors?
What model bora?
08 9n3 Polo GTI
Mods: heaps
actually screw it while I am shopping, if the above is the case what should I pillage for front carriers to fit 312s?
I'll see if I can just find a local wreck and go a bit silly.
08 9n3 Polo GTI
Mods: heaps
Bora V5 and early/original TT I think are the main donor cars. They suit a 256mm vented rotor. I had to replace my calipers 12months back and got them off a Bora V5 in Sydney. Found it searching on google, had to get creative on the search to identify a wrecker. I think they were $70 each from recollection.
If you can source the front 312mm calipers that'd be the win. I drove my red car when Anthony owned it and had done just the rear upgrade and standard fronts, it felt very good, better than my stock braked car ever has, not sure why so much better but it was. I've also driven Gavin's car on the track with the 312mm brakes, you aren't left wanting for more brakes, though for most street applications is probably overkill against a good pad on the stock stuff. The bigger fronts really come into their own at track pace and worth every cent.
Daily: 2010 VW Jetta Highline
Do the bigger brakes greatlyt reduce the chances of fading? That's the only advantage I can see in going beyond the stock brakes (well maybe also lower unsprung weight if you go to a $$$ alloy caliper and rotor hat setup)
Resident grumpy old fart
To my reckoning, there are multiple factors at play. When it comes to fade, the larger rotor provides for greater area for heat absorption and dissipation, therefore peak rotor temps are will be lower for equal braking to a smaller rotor.
Clamping pressure and brake feel at high speed is also much better. So a more consistent pedal and retardation whether you're jumping on the brakes at 180kph or 80kph. I've got the hard data littered through my thread for comparison between my cars, just can't recall the figures off the top of my head. The red car with 312mm and brembo 4 pots, with 256mm vented rears certainly pulls more g's under brakes, when both running the same tyres and both on Remsa pads all round. Now with the A1RM's on the red car, I wouldn't say it brakes any harder in comparison to the Remsa pads, but brake feel and heat tolerance is much better.
I'm pretty certain the brembo's on mine weigh less than the standard calipers too. This was all done by Anthony, I'm just getting the fruits of the labour.
Edit: some data in my thread for comparison - Red Devil mkII - The Journey Continues. pages 22 and 23.
