Originally Posted by
seangti
The red car with 312mm and brembo 4 pots, with 256mm vented rears certainly pulls more g's under brakes, when both running the same tyres and both on Remsa pads all round.
Odd. I could brake hard enough to get the ABS pulsing with the stock 256mm rotor setup on my car while driving with well and truly warmed up semi-slicks. Granted, I had to push the brake pedal fairly hard but there's no way the car was going to be able to pull more braking g's with stronger brakes. I updated to the 288mm GTi setup for the better heat absorption/dissipation reasons you stated since the stock setup would have the pedal going soft at certain tracks.
The only reason I can think of why your red car pulls more g's under brakes is that it is noticeably lighter than the silver one (I'm discounting the aerodynamic differences).
Resident grumpy old fart
