I think you need the same (but please check), from a Mk1 Octavia VRS, TT non quattro, 20th anniv. mkiv golf and a few others.
I had a go at modifying the carriers today, was quite unsuccessful. Going to need the correct ones, not the awd and a spacer (unless you can grind the rotors down by a mm or 2.
