I think you need a VAGCOM man...
I did my last service on my TDI and my dash keep reminding me about that i need an inspection.
I want to reset it so it will remind me to take it for a service at 60,000km
Does anyone know how to reset the reminder in the dash???
Or you can try this:
Reset the display as follows:
– Switch off ignition.
– Press and hold button -1- next to speedometer.
– Switch on ignition.
In display -1 (display unit in centre of dash panel insert) or -2- (display unit in speedometer) of dash panel insert (depending on vehicle equipment) in display unit -1- the note “Service IN” appears or “SERVICE SINCE” or in display unit -2- a “workshop symbol” or a “clock” is displayed. An overdue service is identified additionally by a “minus sign”.
– Release button -1-.
– Turn adjusting knob -1- next to speedometer to right.
The service displayed is being reset and the display in the distance display or centre display changes to the normal state.
okay
that works. haha. I just did it on mine.
You have to hold the button before you put the key in the ignition.
Then you will get a little spanner appear by itself
realease button and turn button right and hold
when it appears back at your km again
turn ignition off and take key out
kdone
those nifty germans never cease to amaze me.
done and done...
cheers fellas![]()
i could have told you that josh! i did work at v-dub lol
good instructions boys!
possible sticky for diy thread?
