Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: rbalc1's 06 Polo GTI
    brisbane
    hope you learnt from the previous owners mistake mate and run g12. i've just had to replace a water pump on an old vw because the housing had been eaten away and i'd put money on the wrong coolant causing the problem...
    Flushed then replaced with G12++ from memory
    A quick little photo dump of the things I have done to the Polo over the past two years
    a) Removed and cleaned the ac fan from behind the glove box. This had a decent build up of dust/dirt from the atmosphere which also had a bit of a smell. Also lubricated the motor with some Inox which seems to have stopped the fan squeaking at low speed.
    I have also cleaned any leaves from the cavity under the wipers.
    Fan speed 1 wasn't working when I bought the car so I replaced the fan speed resistor with an ebay part as VW wanted >$100
    b) Replaced fuse on top of battery. This had a hairline crack due to heat and age. Caused ABS/TCS lights on dash.
    c) Gear shift boot with red stitching
    d) Bought cheap key Fob off ebay and swapped the button pad over to my key
    e) Bought a roll of carpet and cut floor mats by tracing the old mats
    2 X Universal Fixing Grips Clamps Floor Holders Carpet CAR MAT Clips Anti Slip | eBay
    ^these clips fit perfectly over the clips in the carpet and hold the mat in place to stop it from sliding around
    f) Modified aerial seal from a mk4 golf (ebay) --> not a perfect fit as was slightly too big but it looks better than none.
    g) Sanded and polished headlights with Plastx
    h) 3inch dump
    Attached Thumbnails Attached Thumbnails rbalc1's 06 Polo GTI-12366609_1066426793402741_2111124069_n-jpg   rbalc1's 06 Polo GTI-12404379_1073035419408545_1872053223_n-jpg
    rbalc1's 06 Polo GTI-12625699_1087827927929294_668190738_n-jpg   rbalc1's 06 Polo GTI-12212474_1052230264822394_1824403320_n-jpg
    rbalc1's 06 Polo GTI-12212216_1052137854831635_554891688_n-jpg   rbalc1's 06 Polo GTI-12233125_1052198284825592_1950755722_n-jpg
    rbalc1's 06 Polo GTI-11721193_999427323436022_519516153_n-jpg   rbalc1's 06 Polo GTI-12421465_1096583550387065_1192707499_n-jpg
    rbalc1's 06 Polo GTI-12695906_1097088490336571_1248922379_n-jpg   rbalc1's 06 Polo GTI-12782130_1110528628992557_1284640970_n-jpg
    rbalc1's 06 Polo GTI-12935386_1135506163161470_1904672417_n-jpg   rbalc1's 06 Polo GTI-12714347_1103584639686956_6911510_n-jpg
    Fitted a Turbosmart boost gauge into the dash cubby box so it can be tucked away.
    rbalc1's 06 Polo GTI-boost1-jpg
    rbalc1's 06 Polo GTI-boost2-jpg
    nsw
    I like how the boost gauge hides away. Did you have to modify the base panel to make room for the gauge when the lid is shut?
    rbalc1's 06 Polo GTI-16522631_1407409269304490_1987663531_n-jpg
    The cutout I made is about 6cm wide from the edge.
    I also hooked up the power to the dimmer switch next to the headlight switch (light blue wire). Seems to range between 12V and 5 V
    nsw
    very tidy. I like your work.
    Feb 2014
    Gold Coast, Queensland
    Nice update mate. The hidden boost gauge is great rbalc1's 06 Polo GTI
    2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
    Nov 2010
    agreed, hidden boost gauge looks great! KMs are getting up now as well i see, 185k
    2016 MY17 Polo GTI with DA package. TMD fitted + Weather strip and Snow Screen removed otherwise dead standard.
