Results 1 to 9 of 9
Thread: Rain Brings the stink!!
    May 2011
    CAMPBELLTOWN
    Hey, i dunno if it just my car but..
    whenever it has rained my car is smelling real wet and stale! like i wetdog has been jumping around and farting at the same time!
    does any one elses car do this, wandering if it is the sunroof or something!!
    Matty!!
    Aug 2011
    Dandenong, VIC
    wouldn't have a clue if its the same problem but my 2006 Jetta had a bad smell most of the time.
    VW changed the air con filter or something and all sweet.
    Maybe that helps?
    Jun 2009
    Check the drainage from the sunroof, i have heard of tiguan drainage areas that had rotten leaves and stuff in the path.
    I believe there is alsoa tube the can sometimes leak onto the front floor area under the carpet.
    Also check the aircon as it could be causing the smell due to condensation build up and bacteria growth.
    May 2011
    CAMPBELLTOWN
    Quote Originally Posted by fatmir305 View Post
    Maybe that helps?
    thanks, ill check it out=)
    May 2011
    CAMPBELLTOWN
    Quote Originally Posted by team_v View Post
    ill check all of these=)
    wheres this tube??
    im thinking it is a wet carpet smell=(, maybe even a gromet leaking??
    Eltham, Victoria
    Check your passenger footwell. Have a good look under the carpets.
    May 2011
    CAMPBELLTOWN
    Quote Originally Posted by Bflat View Post
    Hey, what shall i be looking for??
    dampness?? and follow from there??
    Jan 2009
    blankedy
    there is a grommet in the fire wall, behind the glove box. Not sure how the rain would get in there, but chances are, its getting in somewhere
    May 2011
    CAMPBELLTOWN
    hmmm theres no grommet there, just the whole!! gahhhh last owner must have taken it offf for something!!
