Results 1 to 5 of 5
Thread: radio harness
    Jan 2012
    Bentleigh East, Melbourne, Vic
    radio harness
    HI guys,
    I have seen quite a few threads on wireing harness' , adapters etc toconnect an alpine headunit to a vw. Besides being a bit confusing, most seem to generalise.
    I called up a audio shop and asked for the price of a wiring harness, and they quoeted $199...bit pricey.
    So my question is, where did you get your harness from, did you get an adapter to adapter, so you could just plug it in on both sides, or did you still have to get 1 adapter, and cut wires on the other side...hope that makes sense.
    Appreciate you assistance, as I am not keen onspendingover $200 to get hs fitted.
    Thanks
    Polo 9n3 GTI
    Oct 2010
    Melbourne, VIC
    This and this will do the trick.
    Resident grumpy old fart
    Adelaide hills, SA
    You can try ebay, also Repco stocks some, and Autobarn has a bigger range too.
    Jan 2009
    blankedy
    Kaanage's 1st link is what I used. Makes install pretty basic.
    Jan 2012
    Thanks guys, and thanks Kaanage (perhaps you should have your own 1-800 helpline)
    Polo 9n3 GTI
