Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
Thread: Radiator Leaking
  1. #41
    Dec 2006
    Quote Originally Posted by Allegiance View Post
    Hi Guys,
    I notice the coolant light comes on every so often, don't know if the radiator is leaking or not though. Is this what occurs for you guys?
    allegiance that is exactly how mine started.
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time.
  2. #42
    May 2007
    West Ryde, NSW
    If coolant light comes in it is most likely a coolant leak. You won't see any leaking on the floor, but if you get under the car and have a good look at the radiator you should spot it. Get the dealer to look at it regardless (it is a common problem) and at least if they dont find anything they will have it recorded in their system so if it becomes obvious out of warranty you have a leg to stand on.
    NickZ
    Former ride: MY07 Black Polo GTI
    Current: MY09 Blue Passat R36 Wagon
  3. #43
    Feb 2010
    Will do! Thanks for the advice!
    2020 VW Golf R
  4. #44
    Mar 2007
    Happening to me as well. The same symptoms. Radiator light started flashing more and more frequently. Originally happened probably a year ago, but dealer said there was a pressure vacuum... they did something and it fixed it for a couple of month, then started happening again. Didn't think much of it.
    Finally, did a check up before warranty ran out at a different dealer, still nothing, but they did replace my radio head unit. Found out about 3 months ago that I need a new radiator, and I'm out of warranty since last August. In the mean time, I've gone through about 2 bottles of coolant... =(
    '07 CW Polo GTI
    'Roof::Leather::Tint
    GIAC::Whiteline RSB + FSB::Forge SB:ogbone
    Glossy B::Cubby::Honeycomb::Antenna
  5. #45
    May 2007
    West Ryde, NSW
    Cygnus - if you have a full dealer service history and noted coolant issues during your warranty period, you may find the dealer will honour the problem, particularly as they are a known problem on the GTI.
    NickZ
  6. #46
    Apr 2011
    Radiator part number?
    Does anyone have the radiator part number for a 2006 polo gti? I'm looking at getting an aftermarket radiator from the U.S.
    Thanks
  7. #47
    Feb 2007
    bright town VIC
    A dealer spare parts department will be able to advise..
    Note that the actual radiator is way less than $300, it's the 4 hoours labour to fit it that is the killer...
  8. #48
    Thirroul N.S.W
    Yeah i think i have the same issue.
    Coolant light keeps coming on as the level of coolant is dipping below the minimum. My 06 GTI has 55k.
    Have gone through a whole bottle of coolant, didn't have much idea what was happening as i had no drips at all, but after reading this thread i think that may have solved the mystery.
    So i figure from the other post you are looking at about $700 to replace it? Anyone recommend a good VW mechanic near Wollongong?
    Dom
  9. #49
    Dec 2007
    Girraween
    After receiving the first batch of new updated radiators not long ago the first unit was installed today. Its very similar in design but the fins are a lot thinner and the crimping where the old radiators leak has been upgraded:
    The old radiator:
    The area of the leak:
    The new radiator:
    Old and new radiator overlapped:
    Euro Revolution - eurorevolution@live.com.au
    Importing Quality Performance and Spare parts for Audi & Watercooled VW's
    New website almost up and running ... http://eurorevolution.webs.com/index.htm
    Courtney
  10. #50
    Dec 2007
    Girraween
    Courtney
