Intended usage should also play a part in the consideration. A high speed flowing track will most likely stress the tyre more making it more likely to fail if it is more than a couple of years old
I bought my first set of semi slicks very cheaply but with the proviso that they were 6 year old stock and likely to have issues if used hard. At the time, I didn't imagine that I would push them too hard, especially since I only drive a TDi. In the 3rd session at Phillip Island (anti-clockwise circuit), the driver side front tyre delaminated which ended my day early. I replaced the tyre with another from the same batch and then the passenger side front failed after a few track days at Winton (clockwise circuit).
At that point, I realized I was pushing the tyres rather hard and bought a new set and had no problems with them for 2 years on all 3 major Victorian circuits, including use in last year's Winton 6 hour relay, until the passenger side front failed at Winton on a very hot day in the last session.
All the tyres were Yokohama A048Rs (old stock were 195/55R15, new stock 205/50/R15). Grip was no problem with the older set - in fact I used the older tyres on the rear with the new ones on the front when testing early this year with no issues (I disconnected the rear anti-roll bar to keep the car balanced while running the reverse staggered set)
If I'd been hill climbing only, I think the original set would still be going.
Resident grumpy old fart
