Results 11 to 20 of 37
Thread: Queensland Raceway - Trackdays
    Feb 2007
    Brisvegas
    Hmmm... I might have a crack at an upcomming lakeside event then... Ever since I saw Brocky, Johnson et al race there in the early 90's I have wanted to have a drive there
    '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
    Jan 2009
    Quote Originally Posted by Spec83 View Post
    you've got 1/03, 5/04, 3/05, 31/5, 12/7, 2/8 etc etc.
    March may be too soon to finance another day (but always easily persuaded if others are going to do it too), April may be a goer
    Nov 2006
    Well, Alex (KI11Z) and I (Ibiza Cupra) will definitely be there. Can't wait.
    BTW, entry fees have gone up considerably from last year from $99 to $189. The track (lakeside) has also just been upgraded along with some facilities. Now we get "carports". Not sure about this but this may be an option and if it is then it will be $40 cheaper if you sont want a carport, don't quote me on this though.
    seangti; what times did you do at QR and with what car?
    '98 SEAT Ibiza Cupra Sport (track/race car)
    '05 CADDY (work/daily runabout)
    Sep 2006
    Brisvegas
    Quote Originally Posted by beeza View Post
    Mate after the email i got on friday i think i dont think this is the case. Its the same price for everyone.
    What makes the rest of the entry fee difference at Lakeside is the $40 levy to help pay for the carports. We are building 100 carports so that everyone gets one.
    The Lakeside Street and Open Sprint rounds don't cost more than the QR sprints when you consider we supply at least 25% more track time and lot more kilometres; 28.5 Vs 50 (or 38 Vs 62.5 if there are minimal recoveries) and guaranteed passenger runs at Lakeside at the end of the day. On $s per minute or $s per kilometer basis the Lakeside series actually cost less than the Ipswich series. Remember the Lakeside series are an all day affair with guaranteed passenger time afterwards and hopefully five runs because everyone stayed on the track.
    Im very keen as well.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Nov 2006
    Ok, then. Thanks for clearing that up Shaneth.
    What's the bet that this "levy" will be applied well after the carports are paid off.
    Kuala Lumpur
    Hi guys,
    It's been quite sometime haven't been posting in here! Anyway, I went for open track day in Sepang International Circuit first time with the Polo GTI last few weeks. Quite a huge turn out with R35 GTR, E60 M5, E92 M3s, E46 M3 CSL, squadron of Evos and DC5 ITR, evergreen 86s and other tuned up cars as well. Known as power circuit, naturally the Polo (albeit chipped) can't keep up with the likes of Evos and BMW Ms but hey some of them was quite surprised how good is the mid range pull!
    Here's some walkthrough on my best run so far (guess you all can do better):
    Drive past through start/finish straight, just about to top 200 before massage the brake 150m from 5th till 2nd, approach Turn1 at 60 take slightly late apex on Turn2, throttle steer the car with front washing wide, full throttle on Turn3 just about to reach 180 before heal-toe downshift to 2nd on 90 deg Turn 4. Build up speed from 80-170 on esses of Turn5 and Turn6. Heal-toe to third taking late apex of Turn7, then Turn8 with almost full throttle applied till 170. Approaching uphill and off camber Turn9 with 2nd, throttle steer the car as the front wash wide again. Flat out at Turn10 then tap the brake for Turn11. Full throttle all the way, again tap the brake, take Turn12 and Turn 13 on 4th. Brake the car in straightline, approach Turn14. Full throttle the car topping 200ish before braking 150m on final Turn15
    I have however some questions in getting the car more track friendly:-
    1. Is there any way to dial more –ve camber on the front? If can it would have turned better at Turn3 and Turn9 where it struggle most with understeer and difficulty in putting the power down properly.
    2. Is there much difference in using other tyres e.g. Yoko Advan, Michelin PPS in comparison with stock Contis?
    3. How much tyre pressure you guys normally dial-in? Is 28 PSI is enough?
    Nov 2006
    Quote Originally Posted by firdausasri View Post
    Hi, I don't have a Polo Gti and i'm not too familiar with them, but i'm sure you can get camber bolts. To get a more responsive Turn-in, just add some Toe out at the front. I only run .5mm but i know some guys run up to 3mm. It really does help with steering response, but i also run 2.5 deg -ve camber which is achieved with the standard camber bolts.
    As far as tyres go, i would definitely opt for semi slick track tyres. It is the single most effective mod you can do. Your times will be at least 2 secs quicker and i'm being conservative. Track tyres require lower initial pressure (25-30). As they get hot, the pressure builds up in them. I run Kumho V70A tyres and i start with 25 front and 28 at the back. When hot they have about 34-36 front and 31-33 back.
    Hope some of the info helps.
    Jan 2009
    firdausasri, I'm damn jealous mate that's just evil
    I've started another thread specific to track days - http://www.vwwatercooled.org.au/newf...ad.php?t=25136, add your story and questions there and hopefully someone can answer your question - I too am keen to get an answer to that cos I reckon there's plenty of room for improvement in the geometry. Think a castor kit would be valuable to help it turn in better too.
    Beeza, where'd you get those prices? I'm look at the QR website entry forms and that suggests $119 + license if prepaid. My first track day was like $75, so it's certainly gone up considerably in 2yrs.
    My times are QR were in the 1.05's, best was a 1:05.4 on shot Yoko C-drive tires. It was a subaru forester GT, run KYB struts, King Springs, front and rear strut braces, rear sway, WRX TMIC, WRX turbo (TD04), Exede ECU at 14psi, Slotted rotor's F&R with Ferodo 2500 pads and 3" TBE. Very lightly modded really, enough to get me to the track and have a blast, though was competitive against lightly modded WRX's and good fun against the Type R's and clio sports - though they were really about .5sec quicker with a competent driver.
    For street tyres on track, I ran 42psi front and 40 rear (I had like a 50series profile tyre though). Will run similar in the Continentals due to soft side wall and adjust as need be.
    Oh, and semi's are worth anything from around 1sec to a few seconds per lap - pending circuit. Probably an realistic few seconds at Sepang.
    Nov 2006
    Seangti, i should have been clearer, i was quoting the entry fee for Lakeside.
    Oh, by the way, Alex and i should be attending QR next saturday. I don't have much interest in QR so i won't be running, but Alex will use the day as a bit of a shakedown for Lakeside.
    Oh yeah, my Ibiza ran a 64.1 on the sprint track, 67.8 on the clubman and a 65.4 at Lakeside last year. No engine mods as such, just a cat back and suspension mods, also those Kumho semi slicks.
    Hope to see you there next week, should be a fun day. It will be Alexs first time on the track. I won't count breaking a CV joint on the first lap on the first corner a day out on the track .
    Jan 2009
    well I'm booked (faxed my entry anyway) and ready to go.
    I'm expecting the times at QR will be around 67sec laps... we'll see in due course I'll keep an eye out for ya's, do the same for me and come say g'day.
