Results 1 to 10 of 18
Thread: PSS9 vs KW V1
    Oct 2009
    PSS9 vs KW V1
    Guys,
    Does anyone have any experience with the Bilstein PSS9 coilover setup and if you do, any comparisons with the KW V1s?
    From what I understand, the PSS9s are damping adjustable as well as height adjustable compared to the V1s which are only height adjustable.
    Looking for something a bit more track orientated as the V1s are pretty soft on the limit.
    Feb 2008
    ACT
    I have PSS9s on my Polo which is used almost exclusively as a track car these days.
    They are height adjustable with the appropriate tools (as are most coilovers), and they are damping adjustable with a simple dial on the bottom of each unit. The adjustment ranges from 'very firm' to 'springs made of concrete'.
    I leave them set to the firmest setting pretty much all the time - although changing the damping rate is very easy (takes no more than 30 seconds per corner) I have gotten so used to the hard setting that I just leave the car that way even for non-track driving. I don't know enough about suspension setup to fiddle with the damping rates to suit a particular track but a smarter person than I might find benefit in setting the suspension to suit the circuit.
    I can't make any comparisons with the KW V1s though - I went straight from the stock suspension to the PSS9s when I bought the car.
    Feb 2007
    Brisvegas
    Jan 2009
    blankedy
    Nice toys, anyone know who's it was?
    Oct 2010
    Melbourne, VIC
    Wow, that's so cheap
    If my struts were still stock, I'd be buying them
    Edit: bugger it - I'm going for them
    Thanks VWindahouse
    Resident grumpy old fart
    Jan 2009
    I'm chasing the sellers rear brake rotors and pads, no one else chase
    Daily: 2010 VW Jetta Highline
    May 2011
    PSS9 vs KW V1
    I noticed that the ad says pss9 golf polo in the title. Would these fit into a MK5 Golf by any chance?
    2007 Golf MKV 2.0 TDI DSG
    | CustomCode Phase1 ECU + DSG | aFe Stage 2 | SprintBooster | KW Variant 3 | 19" Breyton GTS-R | GTI Side Skirts | GTI Front Bar | GTI Shifter
    Oct 2010
    Melbourne, VIC
    No, the Golf it would suit would be a MkIV
    May 2011
    PSS9 vs KW V1
    Coolio. Thanks. Now buy those things.
    Oct 2010
    Melbourne, VIC
    Maybe it was this one (still don't know who owned it...yet)
