Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 118
Thread: Project Polo - 1min10 around Wakefield
    Mar 2009
    Hey guys,
    I run AUTOsports Australia and I'm doing a series of mods only to the brakes, suspension, wheels, tyres and some small aero and weight loss, the ultimate aim being to get into or below 1min 10 or below around Wakefield.
    So far I've run the car stock and posted mid/high 15's.
    With 17x7's 215 Falken RT615's, plus some adjustable coilovers times only dropped to the high 14s, which in all honesty wasn't too bad. The geometry will need some playing around with to really get the most out of it plus the RT615's aren't much better than the continentals that it came with.
    Next up I'll be adding some decent sized front brakes as well as playing around with the suspension to get it handling a lot nicer...
    You can follow the progress on our facebook page AUTOsports Australia | Facebook
    I'd love to hear from anyone who's had success around the track with different bits and pieces (other than engine mods).
    Peter
    Feb 2007
    Brisvegas
    Best of luck Peter, sounds like a decent goal! Just wondering what aero modifications you have planned?
    Cheers.
    Jan 2009
    I'd have bet semi-slicks and coilovers would have got much better returns than 1sec. I gained 2seconds at QR on the sprint track from stock to bilstein and H&R's, on worn out continentals and have done enough laps to be consistent to claim a genuine 2secs. Semi slicks are next. I'm also still running other stock spec.
    Will certainly follow with interest, good to have a plan of attack.
    Mar 2009
    In terms of aero mods I was planning a front splitter/diffuser and a read diffuser... perhaps a small rear wing, but I didn't want anything too OTP. Diffusors are a lot more efficient than wings in terms of the downforce/drag ratio and with no extra power I didn't want to compromise too much top speed.
    With my suspension mods I had to have some custom top hats made up. The maximum neg camber is about 1 degree, although it needs to be closer to 2.5. I haven't adjusted the shocks yet and I don't know what wheel alignment was like (coilover fitment was done by a great mob first time round, but the guys who delivered the coilovers gave me the wrong ones! The guys who fitted the second (the correct ones) were useless, and so I didn't get it aligned the way I wanted)... Once the camber, toe and rear sway bar are on and I have more of a chance to adjust it all, I'll see some better results..
    I think the conti's were actually on par with the 615's, the 615's just didn't get torn to shreds...
    I think once the alignment is where I want it, and the balance is better times will drop another few tenths, but I won't bother going to semi's, I'll just end up going straight to slicks, which should drop at least a full second!
    Feb 2008
    ACT
    Peter,
    Very interested in your thread and your progress - I've got a MY07 Polo GTI that I run on the track, and as a Canberran Wakefield is obviously my local so I've spent a fair bit of time there in the car. Sub 1:10 is my goal on the circuit also, though compared to your target I'm replacing your obvious driving talent (1:14s with stock power is pretty impressive) with power enhancements.
    My previous best in this car is a 1:12.3, on Kumho V70A 205/40 medium compound tyres, in the dry. That was with the APR Stage 1 tune, Bilstein PSS9 coilovers, 323mm Brembos on the front, rear swaybar, Seat intake and running with pretty much no interior trim behind the front seats.
    I can't be objective about the performance gains made through most of the mods individually as 90% of the above was done before I ventured near the track - the only feedback I can give is in terms of R Spec tyres for the track. I tried the Falkens initially but found them no better than the street tyres I was running originally, so gave the Kumhos a go next time around and was very impressed (I bought medium compound as we ran the 2008 Dutton Rally with the car and we had to use the same tyres across the whole rally, including highway transport stages). There was a 2 second difference at Wakefield between the Kumhos and the Falkens.
    I'm now running Toyo R888s (in the softest compound) as the Kumhos were on back-order when I needed them, but I haven't had a dry Wakefield session to report back on those at that circuit.
    swingn on this forum has organised a Wakefield day next Friday 16th July and I believe there's a spot free at the moment. If you can make it to the track I'd love to chat and share ideas - and to see how quickly a proper driver could get my car around the circuit.
    Jun 2009
    You need to look at Plautos build thread - http://www.vwwatercooled.org.au/f127...olo-25317.html
    He has a monster of a pogo GTI
    Mar 2009
    Sydney {GO BLUES}
    i can just crack 1'14"9** but the only suspension mod was a rear sway bar
    apr chip
    apr downpipe
    seat intake
    RSB
    ferodo DS2500
    ebc slotted rotors
    martini brake fluid
    falken rt215 (205/50/16) stock rims
    only removed spare wheel and tool kit
    APR V2 | APR Downpipe + custom catback | APR solid mount | FMIC | SEAT intake | BMC filter | FORGE 007DV | KW v1 | WHITELINE RSB
    139Kw | 271.8Nm atw - At a new home
    Mar 2009
    Sydney {GO BLUES}
    I think i remember trying to chase down you or your brother at Oran Park till i bent my steering..... I would've beaten 1'30 ...
    Jan 2009
    blankedy
    1.10 is an impressive time to hit in the Polo, but doing 1.15's in a stock Polo makes you a much better driver than I am.
    I cant vouch highly enough for James' setup, I was lucky enough to have him take me for a lap last year and it was amazing by comparison. The speed his car could hold through the corners made me eager to get my Polo in shape...
    To be honest, if you said you wanted to hit 1.10, I'd say you were dreaming unless you had some cash, but if you are starting 4 sec of the pace, should not be a problem.
    IMO, a few things to add to your list: Control arm bushes (rear) - stock ones are too soft. Front strut brace - makes a difference for a stock car. Sways may work well with your setup, I do enjoy the whiteline swaybars. I found I had much better handling with wider wheels, lower offset working on the same tyres, might be worth a thought, although you are already running 17's, so you may have the poke lined up.
    James and I will be down at Wakefield next Friday (16th), so will have some feedback for you afterwards...
    Mar 2009
    I'd love to come down next Friday but I don't really have time to make any adjustments to my car (plus I'm out of brakes...) to get any further improvements...
    I'll see what I can do but either way I'll try to get down there just to have a chat and watch... and maybe bring my helmet just in case.
