Results 11 to 20 of 22
Thread: programmable automatic locking
    Dec 2007
    Brisbane, Southside...
    Quote Originally Posted by PeterHBne View Post
    And Jimmy (Jmac) did the auto door lock at 15kmh at my 30,000 service - which, for other S.E Qld owners, was done beautifully and for a fraction of what VW would charge.
    What Peter said in regards to Jimmy.
    I did the auto lock/beep thing myself with my V-Checker. A nice little aftermarket handheld VAG scanning tool.
    Just be careful though. It's all very easy if you have instructions but then you start poking around looking at the descriptions for the different channels. Then you select channel 0 and it just says erased! No menu or description no nothing, just erased. Had to reprogram my remote central locking again. At least I didn't wipe the transponder in the key as well!
    So yes be careful.
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Oct 2006
    With my auto lock feature my passenger side door doesn't unlock when I take the key out like the drivers door does. Is this the same of everyone else?
    Jan 2008
    Do both doors unlock when you press unlock once on the key?
    I think it's the same setting.
    Oct 2006
    I have to press unlock twice for both doors to unlock. At my next service I'll have it changed to both doors unlock on one button to see if both unlock when removing the key from the ignition.
    Mar 2007
    Either one press or removing the key unlocks both doors on mine.
    Dave
    S.E Melbourne
    Only the driver's side unlocks with the remote on mine have to unlock the passangers side with the lock button on the door.
    Is it worth buying VAG-COM?
    May 2007
    Burleigh Heads, Qld
    Quote Originally Posted by DaveMack View Post
    Dave
    Yep - same here - the double click thing drove me nuts.
    I think unlocks boot as well.
    Jan 2008
    Western Sydney
    Quote Originally Posted by Flaps View Post
    mine is like that, and to unlock all doors i need to double click
    Jan 2008
    Lower North Shore
    Before trip to dealer
    Loud BEEP BEEP on unlocking
    No Auto Lock on take off
    Only driver door unlocked with one click
    After trip to dealer
    No beep beep ever again (Thank god)
    Auto Locks at 15kph
    All doors unlock with one click
    Cost - Nothing.
    TIP :- Watch your spare key, it ceases to work once the car is tweaked, make sure you do both at the same time....
    and as for putting the key in the door ? Sorry ??? You have lost me Do what???
    Oct 2006
    Thanks! That explains why my 2nd key doesn't work.
