With my auto lock feature my passenger side door doesn't unlock when I take the key out like the drivers door does. Is this the same of everyone else?
What Peter said in regards to Jimmy.
I did the auto lock/beep thing myself with my V-Checker. A nice little aftermarket handheld VAG scanning tool.
Just be careful though. It's all very easy if you have instructions but then you start poking around looking at the descriptions for the different channels. Then you select channel 0 and it just says erased! No menu or description no nothing, just erased. Had to reprogram my remote central locking again. At least I didn't wipe the transponder in the key as well!
So yes be careful.![]()
2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
Do both doors unlock when you press unlock once on the key?
I think it's the same setting.
FOR SALE
"VW GTI" QLD Prestige Plate
I have to press unlock twice for both doors to unlock. At my next service I'll have it changed to both doors unlock on one button to see if both unlock when removing the key from the ignition.
Either one press or removing the key unlocks both doors on mine.
Dave
Only the driver's side unlocks with the remote on mine have to unlock the passangers side with the lock button on the door.
Is it worth buying VAG-COM?
Before trip to dealer
Loud BEEP BEEP on unlocking
No Auto Lock on take off
Only driver door unlocked with one click
After trip to dealer
No beep beep ever again (Thank god)
Auto Locks at 15kph
All doors unlock with one click
Cost - Nothing.
TIP :- Watch your spare key, it ceases to work once the car is tweaked, make sure you do both at the same time....
and as for putting the key in the door ? Sorry ??? You have lost meDo what???
Thanks! That explains why my 2nd key doesn't work.
