lol so u guys telling me that i put green p/s fluid in to my washer bottle??? lol u boys need glasses lol
I'm sure that's the intention
However, check the position of the tank: after you have managed to get the top off, you will need to be creative about the method you use to add fluid.
Personally, I'd rather change the rear brake pads
well, pre-delivery should check those kind of thing for u, unfortunate my didn't so its was alway low... they don't go low unless there are leaks... but mine didn't leak...
so get ur glasses out, under battery tray is a green looking cap, half covered by the tray... so remove batt & tray, then undo anti clockwise.... mine was on low mark... don't know bout u guys....
hi guys
My steering is so light at first then a 5mins later after taking off from cold start it stiffin up when driving straight and semi light when turning corners...is this normal?
Cheers..I know this probably off topic I apologise...im so new to this
