Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Power steering fluid for Polo?
    Nov 2006
    I'm sure that's the intention
    However, check the position of the tank: after you have managed to get the top off, you will need to be creative about the method you use to add fluid.
    Personally, I'd rather change the rear brake pads
    Nov 2006
    lol so u guys telling me that i put green p/s fluid in to my washer bottle??? lol u boys need glasses lol
    Nov 2006
    well, pre-delivery should check those kind of thing for u, unfortunate my didn't so its was alway low... they don't go low unless there are leaks... but mine didn't leak...
    so get ur glasses out, under battery tray is a green looking cap, half covered by the tray... so remove batt & tray, then undo anti clockwise.... mine was on low mark... don't know bout u guys....
    Nov 2006
    Quote Originally Posted by vw_tech View Post
    Resrvoir is located underneath the battery!!! (just in front) green cap!!You should not mix with non gen fluids!! And No its not fully electric. If the level becomes low It will start to make a noise(eletric pump is inside the reservoir). Tyre pressures are the main thing that will cause lighter or heavy steering. Cheers
    Thankz... lol i felt much better
    Dec 2016
    melbourne
    hi guys
    My steering is so light at first then a 5mins later after taking off from cold start it stiffin up when driving straight and semi light when turning corners...is this normal?
    Cheers..I know this probably off topic I apologise...im so new to this
