not sure if these are accepted when you are "required" to carry chains but look pretty effective
Hey Guys. I scored a job working in Thredbo Resort this winter.
Does anyone have any knowledge on whether snow chains will fit on my GTi riding on stock shocks and HR springs?
There's only approximately 4cm of clearance between the tyre and the bit on the shock that holds the bottom of the spring.
My gut feeling is that this is not enough clearance, or will mean fitting chains will be much more of a pain in the ass than it usually is.
Otherwise, does anyone know where I can pick up some stock springs?
Driving the coal. Low and rattly.
Hi killingwithasmile. You forgot to paste your link, but I am assuming you are referring to 'autosocks'? Laws and Regulations
From what I can gather in NSW, these are only allowed to be used with 4WD or AWD vehicles. FWD still require traditional chains
Driving in the snow
try these - look brilliant!!
Thule Australia » Products » Snow Chains » Thule K-Summit K22 to K45
and require 0cm clearance on rear
2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
Yep, these would work great, except they are $600
But I might just have to bite the bullet.
there's a good debate on snow chains here
What is the official definition of a 'snow chain'
someone suggesting there are cheaper options than the k-summit too
sign up there and say hello, specially if you are going to be a Thredbo regular. I'm debating whether to head off to Thredders this year for holiday. Its expensive from Perth!
taken this morning Thredbo FB
whoops..
this was what i was talking about Home Page > Search > Snow > ES#2137176 Classic C-600 Textile Snow "Chains" - C60062
