Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Polo vs Mini Cooper s
    Jan 2008
    Cremorne, Melbourne
    Quote Originally Posted by FL00DY View Post
    Power @ the wheels of a chipped GTI will be about the 120kw (I'm talking all chips here), power at the wheels of a stock MCS is about 115kw. Think the MCS is a little bit heavier then the GTI. There is a fair bit you can do to both cars to push the power.
    On roads such as Putty or Macq pass, I have no worries keeping up with even JCW's & I'm not chipped.
    older shape MCS (supercharged) = 1140kg and 125kw/220Nm
    new shape MCS (turbocharged) = 1130kg and 128kw/240Nm
    Polo GTI = 1190kg and 110kw/220Nm (standard) or 152kw/328Nm approx. (chipped)
    we are a little on the heavier end but after being chipped, the polo should deliver a whipping due to its high torque. looking at these stats, it looks as though both the older and newer MCS should not be really that much quicker than a standard Polo GTI. all depends on how big the driver is really.
    just my two PSI !!
    Rhys
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
    May 2007
    Burleigh Heads, Qld
    Interesting. I would have thought the Mini was heavier then the Polo.
    I remember reading a quote from a noted motor writer who said that essentially, the biggest difference between a Hyundai and a Mercedes is about 300kg of sound deadning.
    Nov 2006
    Quote Originally Posted by PeterHBne View Post
    Another blind motoring journalist
    Worse still, one of his relos is obviously a designer for Ssang Yong
    May 2007
    Burleigh Heads, Qld
    I think he was looking at the motor vehicle in crude terms - that is all of them being basically the same in specification (4 wheels, motor, gearbox, steering wheel, etc..) and that while refinement in terms of the quality of the materials and the waythey are screwed together varies from car to car, the biggest difference was the amount of sound deadening material used in 'luxury' cars to isolate them from the road and their own noises.
    His point being that there really isn't some sort of Grand Canyon size chasm in terms of innovation between a $200,000 car and a $15,000 car - they are all largely made the same way and with the same components.
