Will you be bringing in other models as well Tim?
Why would you want to give up an air-con vent to have a gauge you're rarely going to look at?
FOR SALE
"VW GTI" QLD Prestige Plate
Yeah TimLet us know when you get it.
I would prefer just the holder without the gauge. Thanks![]()
I'll be very interested in getting one.
I currently run a gauge in a little pod and love to look at the needle move around as you climb on the boost ....
Its been a great help in fine tuning the Forge diverter I have as well. Been able to change boost from 0.9bar sustained to just over 1.0bar sustained by playing with the spring inside the diverter.
Makes a noticable difference in performance throughout the rev range .....
Hmmm from looking at the install guide in the UK forum, the holder appears to be a solidly moulded piece in the shape of the slats, but has no slots between the slats, unlike the ones for the other VW models, also I'm sure the guy who did the install said the back of the mechanical NewSouth gauge would rest against the flap, holding the vent closed. But that obviously depends on the type of gauge used, an electronic guage is shorter and should still allow the flap to open (even though no air could pass through the holder).
the vents are a closed as it was easier to manufacture that way. however the top vents that direct air towards the window remain the same.
