Results 1 to 8 of 8
Thread: Polo tdi with 125k kms, what's likely stuffed?
    Apr 2006
    Melbourne, Victoria
    Hi guys, my wife's 2009 polo tdi has just ticked over 125000kms. It has some creaks in the suspension, what is likely to need replacing?
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    LCA bushes, I bet the tyres aren't worn even either. Replace with Cupra ones or poly for a permanent fix.
    Apr 2006
    Melbourne, Victoria
    Thanks Gavin, any idea where I can source these?
    Quote Originally Posted by hiho View Post
    jmac will have the Cupra ones, otherwise online for the poly ones from superpro or have a look at psituning through the link in my signature.
    melbourne
    i've got some lower control arm front bushes - the seat cupra ones that i never had fitted to my polo because the thing was written off by a landcruiser.
    i see you're in melbourne, too. if i can find em within a couple of days, i'll pm you. i've also got brake stuff (pads, rotors) that are brand new in box. i'm happy to let them go for cheap (like, fcking cheap).
    Apr 2006
    Melbourne, Victoria
    Thanks guys, I ordered lca and swaybar bushes from psi. They arrived yesterday and were a breeze to install. Made a HUGE difference! The old bushes were were wobbly like jelly....
    Apr 2006
    Melbourne, Victoria
    So there is still an annoying clunking that occurs when more than about a quarter turn of steering lock is applied in either direction, usually in conjunction with a rough surface. It does not sound/feel like cv joints. Any suggestions? Ball joints or strut tops perhaps???
    Oct 2010
    Melbourne, VIC
    It could be what some of us are experiencing in this thread Suspension Knock / Rattle Turning at low speed
    If it is, then good luck
    Resident grumpy old fart
