Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Polo suspension and mounts info please.
  1. #21
    Oct 2010
    Melbourne, VIC
    Returning to this old topic, I came across this doc about the Superpro 2-piece lower control arm bushing (whilst delving into the caster issue) and I wondered if they have a similar rear bushing that would prevent the issues that rayray086 discusses?
  2. #22
    Mar 2007
    So, some advice please? Currently, I have the following chassis/suspension upgrades:
    Dogbone mount
    Whiteline swaybars front and back
    Forge Front Brace
    I also have a set of the SEAT control arm rear bushes from Jmac, but they haven't been installed. I am thinking of getting a set of KW V1's and installing the control arm bushes at the same time. Is there anything else that I should do at the same time? Any other bushings that I should look into replacing? control arm front bushes? rear beam mount bushes? strut top bushes?
    I am mainly looking for better power transfer and better cornering, but its completely for street use, and I don't have plans to track the car. In terms of power, I think its got enough for now, so looking at suspension.
    '07 CW Polo GTI
    'Roof::Leather::Tint
    GIAC::Whiteline RSB + FSB::Forge SB:ogbone
    Glossy B::Cubby::Honeycomb::Antenna
  3. #23
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by kaanage View Post
    Fixed the link (stuffed up cut and paste on original post )
  4. #24
    Jan 2009
    blankedy
    Cygnus, pretty much what I have mate. Other bushes should be fine. I also have the rear shims, but I can't say how much they helped. Be prepared for new strut bearings and maybe mounts.
    The other large factor is wheels. I think there is a great benefit in getting as much stance as possible. Obviously tyres, wheel weight and width contribute, but getting the best offset really helps.
  5. #25
    Mar 2007
    ... you mean the ones mentioned from here? For those that have the Bilstein struct bearings and mounts, what are they like? Are the Polo GTI OEM strut bearing and mounts the same as the SEAT Ibiza Cupra R one's?
    '07 CW Polo GTI
  6. #26
    Feb 2008
    Quote Originally Posted by Cygnus View Post
    I have them. To be honest, other then making less noise, they felt no different to stock one. They do the job they are required to do
  7. #27
    Oct 2010
    Melbourne, VIC
    You're loading up your hubs, bearings and steering ball joints and mounts with the extra leverage of insufficient offset, plus it makes your car more prone to torque steer and wander since you are increasing your king pin offset (which also makes for heavier steering). Additionally, you are losing some effective spring stiffness with the extra leverage which will increase roll, although this plus the wider track will reduce weight transfer to the outside tyres so you will get more grip.
    If you are running spacers and your wheels will fit without them, take them off and go for a really good drive to see the effect. Maximising offset so that your tyres only just clear the components inside the arches should be the goal when choosing wider wheels.
