Results 1 to 10 of 10
Thread: polo stock rims
    boxhill
    polo stock rims
    does anyone know whats the stock wheels information?
    whats the stud for polo gti?
    Feb 2007
    Brisvegas
    5x100 makes buy aftermarket rims difficult
    Quote Originally Posted by VWindahouse View Post
    ^^^makes buying NICE after market rims difficult
    5x100 PCD/studpattern
    57.1 centre bore
    I believe the stock gti wheels are 16x6,5et42ish from memory (6.5" wide and a offset of 42)
    with a 205/45???
    boxhill
    thats freaken painful man, why cant it be 114.3x5 T_T
    Feb 2007
    Brisvegas
    So very true dude! The earlier models had a offset of 43 and the later 2008+ models have a 38 offset IIRC.
    Oct 2010
    Melbourne, VIC
    No, it's only the GTi that came with 38mm offset wheels. The other models kept getting 43m offset wheels.
    Even the 6R Polos have high offset wheels (46mm for the new GTI)
    As for finding 5/100 wheels, a lot of us have ended up buying from o/s since you can only really get 17"+ 5/100 wheels here for the Suburus
    Resident grumpy old fart
    GTI came out with ET43 and ET38.
    Pretty sure Ant's stockers were 43 and mine were 38. Wierd.
    I'd love to know why.
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
    Feb 2007
    Brisvegas
    Quote Originally Posted by spraycanmansam View Post
    Correct Sir
    Quote Originally Posted by kaanage View Post
    Guys I have a set of WRX MY2006 OEM 17 inch alloy Enkie wheels. So what VW's will they fit? I have a 2008 Polo Gti will they fit it?
    Did a trial fit and they will not go over the centre on front hubs.
    Cheers Al
    Feb 2008
    polo stock rims
    What's the offset?? Subi rims generally won't fit without spacers.
