Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 91 to 100 of 111
Thread: Polo Stereo Advice
  1. #91
    Oct 2009
    Templestowe, VIC
    Quote Originally Posted by ef9 View Post
    I've ran the power cable for the sound system today (throught the passenger side kick panel to the left front guard into the engine bay)
    Took some pictures also, let me know if anyone is interested, i can post them up here.
    Yeah put them up mate!
    Worth having here for reference
    MY11 Skoda Octavia vRS wagon 147TSI DSG
  2. #92
    Aug 2009
    West Footscray, VIC
    Quote Originally Posted by xc17ed View Post
    Is this the correct adapter for an 06 Polo GTi?
    http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWAX:IT
    that's the one i have, but you will need to either:
    1: cut the iso plug off (the two small plugs) and connect it to your headunit's harness.
    2: buy a ISO to Sony/Pioneer or (other brand) harness (which means you don't have to use the original harness from Sony/Pioneer etc...) and this is the approach i went with. (about $20), no cutting, pretty much cut and play.
    Black|APR Tuned|APR Dogbone|SEAT Intake|BMC Airfilter|Forge TIP|SEATSports Front Strutbrace|Forge Rear Strutbrace|Whiteline RSB|Bilstein B8 & H&R Springs
  3. #93
    Jan 2010
    cutting off and joining shouldn't be too much of an issue as long as the factory loom doesn't have to be cut. Now I'm willing to give the can connector a miss and hard wire the acc of the ant wire. That just leaves me needing an antenna converter for the moment correct? Once the hu is fitted I'll need a stereo facia as well to suit? I'm thinking either the pioneer with nav most of you have or a more basic clarion dbl din DVD model.
  4. #94
    Aug 2009
    West Footscray, VIC
    you are right, cutting and joining is not hard at all.
    Re: antenna converter, that's what you need, i got the one with no amplifier, and it's working fine for me.
    Re: facia for double din; no comment, as i have a single din HU, and no facia.
  5. #95
    Jan 2010
    Can you show me which one you have and possibly the "common" one one with amplifer?
  6. #96
    Aug 2009
    West Footscray, VIC
    This is the one i got:
    http://cgi.ebay.com.au/PC5-100-Volks...item23028ace94
  7. #97
    Oct 2009
    Templestowe, VIC
    This is the fascia kit I used with my AVIC F900BT.
    http://www.dynamicsounds.co.uk/conne...le-p-1262.html
    Fits nicely, I trimmed the front panel so it fit more flush.
    I used this powered aerial adapter too.
    http://www.dynamicsounds.co.uk/autol...or-p-9280.html
  8. #98
    Jun 2009
    Caz'bah
    I used that power aerial adapter too but now have shocking AM reception where it used to be crystal clear.
    I'm thinking I've hooked it up wrong.
    Where is the little blue cable supposed to go?
  9. #99
    Oct 2009
    Templestowe, VIC
    Quote Originally Posted by danish View Post
    It goes to the antenna power output on your head unit. Should be able to hook it up to any switched 12v source anyway.
  10. #100
    Jan 2010
    Many people had experience with these?
    (single din) http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWAX:IT
    (double din) http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWAX:IT
    Thanks to ef9 for showing me these.
