You are the man!!!! i installed my headunit today, and the antenna wire works just like you said, and behaves just like stock
I brought a VW to ISO wire adapter, the antenna adapter, and a facia kit from ebay for my single din headunit, it turns out i got the wrong facia kit, i ended up installing the HU without a facia kit, just used the pocket that came with it. It doesn't look factory at all, but i'm happy with it.
I also brought an ISO to Pioneer harness from autobarn, i ended up installing the HU without cutting any wire or even pulling out the battery (i know i should have, but got lazy, and it's damn hot in Melb right now).
The only thing is you will need to pull the 12V red wire out of the connector, and put it back in to the Antenna slot on the connector to match the antenna connection.
