Page 6 of 12 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 111
Thread: Polo Stereo Advice
  1. #51
    Aug 2009
    West Footscray, VIC
    Quote Originally Posted by leasaunce View Post
    I think you might, for "ACC" (power)
    emmm.....can't i just joint the red wire (from the pioneer/sony harness) to the VW wire which only has power when the key is turned to ACC? or does the VW not have one? (becase we can turn the HU on even when the key is out)
    Edit:
    Did some more searching and found this thread with almost everything i needed, still some unanswered questions but it's a good start.
    http://www.vwwatercooled.org.au/newf...eadunit&page=5
    some said to use the cig/lighter wire, and the HU will switch off after the key is out, and some says it will stay on for an hour. Also some says there is an accessory wire, and some says there isn't, this is the only dilema at the moment. Will give it a crack once my kit/harness arrives, can't wait.
    Black|APR Tuned|APR Dogbone|SEAT Intake|BMC Airfilter|Forge TIP|SEATSports Front Strutbrace|Forge Rear Strutbrace|Whiteline RSB|Bilstein B8 & H&R Springs
  2. #52
    Oct 2009
    Templestowe, VIC
    http://www.dynamicsounds.co.uk/conne...lk-p-9117.html
    That's all you need. It's a CANBUS adapter which will give you the appropriate outputs (illumination, accessory, speed sense etc) which you won't find in the Polo's loom. The CANBUS adapter also has 2x ISO plugs with all the other outputs (constant 12v, speakers, etc) which you can either cut the plugs and wire to your head unit's harness, or buy an ISO adapter to work between the CANBUS adapter and your head unit.
    You'll also need an antenna adapter to turn the VW's ISO antenna plug into a regular car stereo one.
  3. #53
    Aug 2009
    West Footscray, VIC
    Quote Originally Posted by tooch View Post
    Thanks tooch, i've already paid for the standard wiring adapter, along with the facia kit and antenna adepter. I will see how it goes when they arrive. Thanks for the link, at least i know what i need if the one i have ordered causes any problems.
    This is what i've got:
    http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWAX:IT
    Cheers.
  4. #54
    Oct 2009
    Templestowe, VIC
    You can always just run an accessory wire from the cigarette lighter if need be. I just want to make mine as factory as possible, hence the canbus thing
    I still haven't even got a head unit yet, my source for the cheap Eclipse AVN726 has fallen through I think, so gotta start looking around again
    I'll be interested to see how you go with those speaker adapters and the Infinity's
  5. #55
    Aug 2009
    West Footscray, VIC
    will let u know how i go, and perhaps post some pic
  6. #56
    Oct 2009
    Templestowe, VIC
    Well looks like I'm probably getting a Pioneer F900BT now as I can get one very cheaply through a source
    So I just ordered the following from Dynamic Sounds in the UK.
    1 x Connects 2 CT23VW03A -Polo Double Din (CT23VW03A) = £28.95
    1 x Autoleads PC5-137 - DIN Aerial Adaptor (PC5-137) = £7.99
    1 x Connects 2 CTSVW002 - £33.99
    1 x Autoleads PC5-133 - Volkswagen Radio Removal Keys (PC5-133) = £2.99
    Came to $185 including shipping thanks to our dollar being good with the GBP at the moment.
    Considering most stores here sell that EXACT connects2 CANBUS adapter for close to $200, its a bargain
  7. #57
    Jun 2009
    Caz'bah
    Just finished the install of my Pioneer AVIC F310BT tonight
    Followed the guidance here with the wiring loom purchase, fascia from nexxus and aerial adaptor.
    All in all only took about an hour from go to woah.... although it took me 3 days to get the stock unit out
    Heres the unit installed:
    Mic run up the A-pillar:
    iPod connector run under the steering column, popping out in the tray underneath:
    I mounted the GPS underneath the top tray on the dash, gets perfect reception and completely hidden, far superior to having it sitting on the dash, thats for sure.
  8. #58
    Jun 2008
    I got my AVIC HD3. Since then im loving it! I'm still waiting for the fascia cover as they're custom making it (didn't come with in the package from Pionner). Let me tell you, if anyone of you guys wanna get one of these GPS LCD, make sure you have a CANBUS. if not goodluck
    Installed the Microphone in one of the spare buttons so its hidden away (next to the Defogger switch)
    GPS is under the top dash.
    Gyro Sensor (measures left,right,forward,reverse,slope, G-force, altitude and so on). Works superb in tunnels or when you don't have the GPS signal
    Thanks To FHRX Studios for putting them on and getting a Focal subwoofer in couple of weeks!
  9. #59
    Oct 2009
    Templestowe, VIC
    I put my AVIC F900BT in today. The actual install process was pretty easy, but the unit wouldn't power on. Checked and double checked all the wiring, all was ok. Did some investigation and figured out that the Connects2 CANBUS adapter doesn't work
    Will have to send it back. For the mean time though, I've got the ignition switching wire coming from the power antenna wire. Switches on with the ignition, and turns off when you remove the key! Surprised nobody has noted this before.
    Everything works as it should, GPS probably won't be 100% until I get the canbus adapter sorted.
    Connects2 double din fitting kit is pretty good, can't get the unit completely flush due to all the wiring and crap at the back, but its good enough.
    Massive thanks to No Limit Electronics in City Rd. Sth Melbourne for removing the stock deck for me as I had the wrong keys. Very helpful and friendly guys, I'd recommend going there for any professional car audio stuff.
    Much more than I can say for another local shop who I won't name, but we'll call "Gareth's", quite well known car audio shop.
    MY11 Skoda Octavia vRS wagon 147TSI DSG
  10. #60
    Aug 2009
    How much they quote to remove the stock deck? Was it just you borrowed the keys to pull it out, or did they do the installation too, I just need someone with keys to pull mine out, Ive got all the bits and pieces ready pretty much to put my Clarion DDIN HU in...
