I put my AVIC F900BT in today. The actual install process was pretty easy, but the unit wouldn't power on. Checked and double checked all the wiring, all was ok. Did some investigation and figured out that the Connects2 CANBUS adapter doesn't work
Will have to send it back. For the mean time though, I've got the ignition switching wire coming from the power antenna wire. Switches on with the ignition, and turns off when you remove the key! Surprised nobody has noted this before.
Everything works as it should, GPS probably won't be 100% until I get the canbus adapter sorted.
Connects2 double din fitting kit is pretty good, can't get the unit completely flush due to all the wiring and crap at the back, but its good enough.
Massive thanks to No Limit Electronics in City Rd. Sth Melbourne for removing the stock deck for me as I had the wrong keys. Very helpful and friendly guys, I'd recommend going there for any professional car audio stuff.
Much more than I can say for another local shop who I won't name, but we'll call "Gareth's", quite well known car audio shop.
