Page 26 of 37 FirstFirst ... 16242526272836 ... LastLast
Results 251 to 260 of 370
Thread: Polo Problems & Fix Register
  1. #251
    Essendon
    I'm no grease expert, but if grease at any point breaks down into oil, then it's no longer grease and therefore no longer doing the job it was designed for.
    I can't imagine VW would use some crappy grease that would break down into oil. If indeed, grease can do that.
    Sunroof // ICT Tint // Seats // Steering wheel
  2. #252
    I know, the stuff is the same consistency as oil...maybe a little thicker than engine oil but not much. Maybe I should take it to an independent and get them to look at it, but then I think, I bought a new car so I could have a warranty..why should I have to pay to get it looked at.
  3. #253
    Aug 2009
    I'm having issues every now and again trying to shift into 1st gear at a standstill.
    Sometimes the issue is remedied by shifting into second, then up from second into first... other times I just can't get into 1st no matter what so I need to start in 2nd.
    Anyone had a similar issue?
    Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
    Current Ride: Evo 8 MR, Fabia MK3
  4. #254
    Jan 2009
    Quote Originally Posted by break View Post
    is it any easier with a few revs? or if you release and depress the clutch before engaging first?
    An old car I had had stuffed syncho's and this made life easier.
  5. #255
    Aug 2009
    Quote Originally Posted by seangti View Post
    Haven't really tried pulling revs in before/during engagement, but releasing the clutch fully and depressing again doesn't help it at all.
    It's weird... only happens every now and again. And my box is find with the 1st to 2nd shift at high rpm, which many other boxes seem to have issues with.
  6. #256
    Jul 2005
    make - polo gti
    kms - 45000
    mods - none
    car usage - daily
    problem - gearbox
    description - crunching into second gear again.
    fix - took it it back to the dealer the first time and they replaced the gearbox oil. This seemed to work for a few months and now it is doing it again.
    gearbox is being rebuilt.
    Gearbox is now rebuilt, they replaced the synchros for second gear. Car so far is running great again.
    problem - power steering.
    description - at low speeds the power steering is making a groaning noise.
    fix - power steering pump to be replaced. pump has failed.
    Power steering pump has been replaced and so far running fine.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
  7. #257
    Jul 2005
    make - polo gti
    kms - 46000
    mods - none
    car usage - daily
    problem - power steering (or so i thought).
    description - whilst parking the steering is making a different noise to the previous problem (see previous post).
    fix - replaced both front strut top bearing plates. They said they were scraping. no noise on drive home last night.
  8. #258
    Oct 2009
    syd
    If you ever have any transmission issues, only use transmission oil from VW, don't bother using anything else.
  9. #259
    Feb 2008
    Quote Originally Posted by Hilal View Post
    Alot of the guys use Redline on here to cure any problems they have with the gearboxes...Talk to Jmac, he will fix you up with it.
  10. #260
    Oct 2009
    syd
    Oh! Look at that!! Maybe there is an aftermarket oil that works fine without any synchro crunching :O
